Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
