QUick and dirty this is how it should go. Might be a little different so use some caution.
1- Remove the 4 screws from the outer corners of the gps unit. These are on the back in the corners.
2- Try sticking a small (JEWELERS/PRECISION) screw driver between the two halves of the case. There are small snap locks around the case, these are what you are trying to get to open up.
3- When you get the two halves seperated do not pull them apart. Look carefully inside you might see wires running to tha back half of the case, check on these and see where they go and what they are connected to. If you are lucky they are just speakers and they will have a quick connect on them.
4- Once you have the case seperated, the battery should be right there, remove the battery and install the new one. NOTE-- IMPORTANT sometimes you cannot get the right battery but you can get the same one but with a different end on it. IF YOU are CAREFULL you may be able to get the end off the original battery and put it on the new one.
Hope this helps you out and good luck.
