Question about Sony Cyber-shot DSC-H5 Digital Camera
Sony DSC H5 runs down batteries very rapidly. Much faster than when the camera was originally purchased. A pair of new AA batteries only lasts for 12 - 24 photos. Brand new rechargeables fully charged are totally drained after sitting in the camera for a few weeks with no use. The camera is definitely OFF. This did not happen three years ago when I bought the camera, it started in the last 6 months. I can't go on like this!
RAJDEEP DUTTA
  • Sony Master
  • 2,517 Answers
Hi there please reset the camera 1st . THen pair your battery with your camera. Go in menu then battery type option. Select the type of a battery. After that save the setting. Now try . If you face the same problem then the camera internal power transformer are damaged or week. So you need to replace that transformer after that it will start work properly. You use that camera so long, that's why there is a chance of that damaged. Thanks if its helpful then rating me.
Posted on Mar 15, 2010
  • vahitkaya Jun 17, 2011
    i think you are right. hanks alot.
    can we change the transformer at home? is it easy? or shoul i go to the service? and how can i find the part that will change? i am living in Turkey. :)
  • kaffeefreund
    kaffeefreund Sep 10, 2012
    I'm having exactly the same problem. Did you manage to fix it on your own? How? Thx! :-)
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Jan 06, 2011 | Kodak EasyShare C663 Digital Camera
The battery is run down every time I come to use the camera. So it seems to bleed out power even when turned off. I have replaced the original battery and the new battery also runs out while sitting turned...
This is not a common/generic problem for this camera, we need to be a bit more creative into it resolution.
I am assuming that you have already checked for accidental 'power on' of the camera prior to reporting it. By accidental power on, i mean that as this is one of those semi-pro dslr cameras you need to make sure that the power is turned off before you replace the lens cap as otherwise you can mistakingly leave the camera on while the covered lens will show nothing on the lcd/viewfinder display.
Check the time it takes for you to charge your battery. It should take a minimum of 5.5 hours to charge the battery fully. If the charging light on the charger turns off before then, continue charging for the next couple of hours. Try using the batteries again. Also, please note that temperature is very important both during usage and charging. As per Sony, the optimum charging temperature is 25 degrees C or 77 degrees F. In colder areas, battery power runs out extremely fast.
Aug 21, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
I have a Sony DSC-H5 and the shutter button does not allow me to push it half way -- only all-the-way -- the macro won't focus.
It is a common problem on this model. You need to replace the control assembly to fix the problem. Here is a link to show you how to replace the assembly and where to get the part.
How to replace the shutter button on SONY CyberShot DSC-H5 digital camera
Jun 08, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Sony DSC H-5 Camera slow response time
There is a diaphram between the shutter button and the shutter that does the focus. Pushing the button half way down pre-focuses and then the picture is instantanious. If the diaphram is broken it take a while before the shutter takes the picture. One of the AA batteries may be defective so try another set and see if that is better. There is also a slight possibility that the secondary battery (hidden within the camera) has gone bad.
May 27, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Shutter button popped off & I am out of warrenty.
You can replace it DIY. Here is a link show you how to replace the button and where you can get the parts.
Mar 17, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Pictures out of focus suddenly
Make sure the lens is clean and does not have greasy residue on it.
May 07, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Digicam problem
Is it rechargable batteries (orignal for the camera), or are you using standard batteries? (AA/RC6 kind of batteries)
If you use AA batteries (or similar) make sure you use alkaline batteries of a good brand. Cheap batteries ofteh don't have the power to run digital cameras. Especially using the LCD screen drains the batteries.
If you have a new rechargable battery and it last only a short time see if using it and recharging it a few times helps the bettery "getting into it". If not, your camera may need repairs.
Mar 13, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cyber-shot DSC-H5 Digital Camera Logo
969 people viewed this question
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
