Question about Alpine CDA-9884 Car CD/ MP3 Player
How do you setup the clock so that it shows all the time? How do you setup the bluetooth to an iphone?
Posted by lbigrunner on
Anonymous
    New Friend:
  • 180 Answers
Ive had a good look round for you , and i have found a manual for you to download, this describes how to set the clock..mark.
http://www.retrevo.com/support/Alpine-CDA-9884-Car-Receivers-manual/id/23223ci369/t/2/
Posted on Mar 18, 2010
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
Jan 13, 2018 | Cars & Trucks
Setting up Bluetooth in car
Go into the Bluetooth settings of the iPhone when in the original car, Check that Bluetooth is on in both the car and on the phone. Then in the Bluetooth settings of the iPhone, there should be a list of devices and one of them should be your car. just tap on that and it should connect.
Apr 19, 2016 | Apple iPhone Cell Phones
Pairing iphone 4s to 2010 mazda 3 bluetooth
1.) Enable Bluetooth on your phone/device and go to "search for devices" on it. Pic below is the screen on the iPhone, go to "settings" and then "general" to get there:
2.) Push the audio control button on the right side of your stereo on your speed3 a few times until "BT Setup" shows up and then spin to the right to choose "pair device" and click it.
3.) After a delay "Mazda" should show up on your device list on the iPhone. Choose it and then enter the pin "0000" and it should connect.
Aug 11, 2013 | Apple iPhone 3G
When I turn my iPhone Bluetooth on it won't find the Craig blue tooth speaker!
Any Bluetooth device MUST be discoverable for the phone to find it.
Does your Craig have any setup program / configuration where you can set it to be 'discoverable' ?
Feb 17, 2013 | Cell Phones
Iphone bluetooth drops to headset if in my hand
hello, I also meet this error about my iphone, I get many help from this forum, and also bought many DIY repair tools from china supplier, and vipprogrammer help me fix this error. maybe you can try it. or contact they WhatsApp:+ 8615986801289
Link: http://www.vipprogrammer.com.
hope can help you!
Aug 20, 2017 | Apple iPhone 3G
Can't pair to iphone 3g
Hi, the iPhone 3G definitely does work with bluetooth. In fact, I'm talking on a bluetooth headset with my iPhone 3G right now.
You have to put both your Southern Telecom Emerson Bluetooth Headsetand the iPhone in "pairing mode".
On your iPhone, click the Menu button, tap the Settings icon, tap the General icon, and then tap the Bluetooth icon. Make sure that 'Bluetooth' is set to "ON" and not "OFF". As long as you have this screen up, your iPhone is in pairing mode.
Turn your Southern Telecom Emerson Bluetooth Headset off and wait a few seconds. On your Southern Telecom Emerson Bluetooth Headset, press and hold and Answer/End button for Five Seconds, until a solid blue light comes on, which places the device in Bluetooth discoverable mode.
Now that both devices are 'discoverable', the Southern Telecom Emerson Bluetooth Headset will show up on that Bluetooth screen on your iPhone. Be patient as it might take a minute to appear. Tap on the Southern Telecom Emerson Bluetooth Headsetin the list on your iPhone, and then it will ask you for a passkey. The passkey is "0000" (without the quotes). After you enter the passkey, the Southern Telecom Emerson Bluetooth Headset will show up on the list with the word "Paired" next to it.
Now you're paired! Incoming calls will automatically be passed to your headset as long as your iPhone can find it nearby.
Good luck.
Feb 23, 2011 | Southern Telecom Emerson Bluetooth Headset...
Thx for advice but i can pair my phone with the car but i cant manage to pair my contacts from phone to the car there is not bluetooth options in iphone...
I found this welcome surprise after the 3.0 iPhone software upgrade a couple months ago...
Problem: I had too many contacts on my iPhone syncing with my car making it tough to scroll to my desired contact.
SOLUTION: Setup a 'GROUP' in your iPhone's Contacts which lists only those people you want to have available while in your car; Next, goto Settings, General, Bluetooth, MB Phonesystem (or your Bluetooth name) and choose the GROUP you want synced.
The new setting will take effect the next time you sync with your car (you might have to restart bluetooth on your iPhone to make the selection stick).
Hope helps.
Jan 28, 2010 | Car Audio & Video
I want to use my iphone 3g bluetooth in every situation
You can't send and receive files with the iPhone's bluetooth. Version 3 of their firmware will supposedly provide this functionality, but only on the iPhone 3G. (2G models don't have the necessary hardware)
As for the hands-free car setup, that should work just fine. It's a matter of pairing the two devices together.
Apr 20, 2009 | Apple iPhone 3G
BLUETOOTH
Hello dmydeuce,
The setup you describe is possible, however you will want to make sure that your MP3 player, phone and headphones support both A2DP (Advanced Audio Distribution Profile) and also AVRCP (Audio/Video Remote Control Profile) protocols. Additionally in order to answer incoming phonecalls the headphones will need to have a built-in microphone. Check the documentation on your products.
Best Regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Audio Players & Recorders
Alpine CDA-9884 Car CD/ MP3 Player Logo
208 people viewed this question
Top Alpine Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
