Question about Canon PowerShot SX100 IS Digital Camera
How do I adjust the shutter speed - Canon PowerShot SX100 IS Digital Camera
Posted by testmyskil on
Glyn Kendall
  • 146 Answers
Set the mode dial on the top of the camera to Tv.
Use the control dial on the back to change the shutter speed.
The aperture value is shown on the screen at the bottom.
If it is shown in red the picture will not expose correctly.
Adjust the dial until the value is white.
I hope this helps.
Posted on Mar 15, 2010
I just bought the minolta XG-A, will I be able to adjust manually the shutter speed? I just bought it only, still has not been shipped. I bought it mainly for a film photography class but I just read that...
Minolta XG-A can work in full manual mode. The lowest shutter speed is 1 second and it had Bulb mode where the shutter is open as long as you press the button.
Sep 12, 2013 | Minolta XG-A 35mm SLR Camera
How to set shutter speed in fuji fine pix S2940
That depends on the exposure mode. In any of the automatic point&shoot modes you have no control over the shutter speed, the camera sets what it thinks is the proper shutter speed. In the P (Program AE) mode you can adjust the shutter speed by pressing the +/- button. In the S (Shutter Priority) and M (Manual) modes you control the shutter speed by pressing the +/- button and then using the cursor-up/down buttons.
Apr 25, 2012 | FUJIFILM S2940 Digital Camera
How do I change the shutter speed on a Nikon EM film SLR
The EM doesn't really have a manual shutter speed setting. It does have a Bulb setting for long exposures and a 1/90 second manual for flash, but otherwise the camera automatically sets the shutter speed to go with the currently selected aperture.
Normally you would set the aperture and let the camera set the shutter speed. You can adjust the shutter speed by pressing the exposure compensation button for +2 stops. You can also adjust the exposure by changing the ASA/ISO setting.
If you need a manual, you can download one from http://butkus.org/chinon/nikon/nikon_em/nikon_em.htm
Jun 29, 2010 | Nikon EM 35mm SLR Camera
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
Adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
May 01, 2009 | Olympus Stylus / mju 1050 SW Digital...
Shutter Speed Adjustments
Use the M (Manual) or S (Shutter Priority) modes. See the manual for details on using these modes and setting shutter, aperture, etc.
Unfortunately, Panasonic's website is not properly linking to the user manual so I can't download the manual to provide you with the exact steps on how to set the shutter in the M or S modes.
Dec 27, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Shutter speed won't go above 200
I have two possible solutions:
First, are you shooting with the flash up or an external flash connected to it? If so, the camera likely needs to synchronize at 1/200 or slower otherwise it won't be able to take a full photo. As a safety feature to prevent that, many new cameras just restrict the ability to pick a faster shutter speed.
Second, if its not related to the flash, it might be related to the mode you are using. Turn the camera off the automatic modes and put it on an all manual setting. Change the ISO to 400 or so, got outside and aim up at the day's sky, put it on manual mode and then adjust the shutter speed. Open up the aperture on your lens all the way (turn it to the smallest number). Now adjust the shutter speeds. It should be able to go past 200 now.
Nov 25, 2008 | Canon EOS Rebel G 35mm SLR Camera
F-stop issues
See pages 36&37 of the manual.
If you haven't got one, you can download it here.
In M mode...
Turn the selector dial to adjust shutter speed.
Hold down the AV+/- button (top-right of rear screen) and turn selector dial to adjust aperture setting.
As for Av mode, this is perfectly normal that you cannot set the shutter speed. Av mode means that you decide on the aperture setting and the camera (not you!) decides on the correct shutter speed.
Hope this helps,
Matt.
Mar 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Panasonic DMC FZ30 shutter speed adjustment
set to s -then adjust using command wheel by thumb- 8 secs to 1/2000
Jan 20, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Shutter speed Panasonic DMC FZ30
set dial to s-then adjust to desired setting using command wheel by thumb.
Canon PowerShot SX100 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
