Nikon D70s Digital Camera Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"Err" code D70 gives me an "Err" code. How do I fix this? The image is about 4 stops underexposed.
pictureman4u
Level 2:
  • Expert 132 Answers
  • Posted on Mar 26, 2010
pictureman4u
Expert
Level 2:
Answers
132
Questions
0
Helped
43954
Points
329
Try locking your lens on the f22 setting...that's what it sounds like your problem is....
1helpful
Err message on D70 and clock flashes
D70..err display...problem with the loader section switch,rotating while loading is open,so get it repaired.
D70 ERR at the power on
More than likely two things ... The blower tip touiched the blades or the sequence plate is defective . BERRIE SMITH CAMERA REPAIR
[email protected]
2answers
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Nikon D70 ERR problem ,
its apparture unit has faulted. it has to be replaced
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
1helpful
3answers
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Problem with underexposed pictures
I've got the same problem with my new ef 500 dg super and my ef 530 dg super. It occurs on all nikon camera's I could get.
D70, D80 and Fuji S5 Pro. I don't have this problem with an old (4 years) sigma ef 500 dg super.
I will try to contact Sigma for this problem.
2answers
Memor Card Access Lamp blinks constantly
I have no solution, but I wanted to add that I am having this same problem. You are, unfortunately, not alone. Jean
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
