Check for 24v.hum transformer shuold interlock/power up during blower motor hearing speed operation.Make sure its running.also manual mode resistor has to be installed in control panel.a blue plastic tag w/2 ends.
Check if there is power to the solenoid valve, if ther is , then the solenoid is bad and must be replaced. If there is no power could be a bad humidistat or transformer.
Hello, most likely the solenoid is bad and must be replaced. If you are getting 24 volts to the solenoid and it does not open replace the solenoid valve.
The solenoid valve unit will work upside down however, I am concerned that the tech that installed the unit might have installed it backwards. Look on the side of the valve the solenoid is connected to and you should find an arrow. Thats the direction of the water flow.A strainer helps keep the valve clean however if there is dirt in the valve it would be stuck opened not closed. Make sure the solenoid is getting power via float valve. If the solenoid is getting power you can tell by touching the top of the solenoid with a metal non magnetic screw driver. It will pull the screw driver like a magnet. Good luck
The first thing you want to check is that the saddle valve is open and that water is getting to the solenoid. If you are getting water to the solenoid but it's not going through then most likely you are not getting power to the solenoid. When there is a call for heat you should be getting 24 volts to the solenoid and it will open allowing water into the humidifier, if you are not getting 24 volts then check the transformer make sure it is giving you 24 volts.
The solenoid will not open with only 13 volts to it. Jump or apply the full 24-27 volts to the solenoid and see if it clicks and opens and allows water to flow.
If the valve still won't open or pass water, start looking for a plugged inlet solenoid inlet screen or a faulty solenoid valve as well as a faulty humidistat.
if it works in the test mode then it should be okay but you can get a humidity gauge from radio shack and set in the house to see how high or low its is. the humidifier is only going to give a max of 45% humidity
Yes, just check to see if you have 24 volts going into the solenoid. If you do and it is not opening its probably bad. Since you verified the water lines, filter, orifice and saddle valves are not obstructed. Change the solenoid valve. When you price the part. (it's not cheap) consider paying about 30% more and just change the whole unit.
Good luk
HVAC Teacher
solenoid valves dont just burn up just like that you have a recurring restriction due to bad water.Check the saddle valve at the water heater first then check for postive water flow at inlet to the solenoid valve,if you have water flow the valve is clogged with sediment.
These units have simple configurations They have a water supply similar to a ice making referigerator, an enclosure connected to your supply duct that houses a prop fan and media, a seperate humidistat and a drain for excess water. Your unit may also include fancy controls including an outside thermometer & humidistat to avoid over humidification that can cause problems during freezing weather. The humidistat looks a lot like a thermostat and is located in your living space or in the return duct. The prop fan in the box pulls air from the duct, through evaporation media and back to the duct. An electric solenoid valve releases water that pours over the media.
If the humidiy is below the humidistat seting and the AC/heater is running, the Aprilaire fan starts and the solenoid valve opens. I suspect the facier controls include the flashing warning light.
The warning light spells problem. Aprilaire's customer service should be able to provide guidance for the homeowner in the form of simple checks. I suspect your contractor is avoiding a warentee call and the trip it requires.
A word of caution. These humidifiers can be powered directly from your air conditioning unit control board from an auxiliary connection. If the control board isn't rated to carry the current required by the Aprilaire fan, valve and controls or the Aprilaire encounters and electrical problem, the board can be damaged. This can be avoided by using a relay. The AC board switches a low energy relay. 120 volt house power is connected to load side of the relay and runs the Aprilaire.
My board cooked at a location near this connection, but I can't be sure that the load from the humidifier caused it since four of our neighbors also lost their board. It failed the evening of a snow storm and required a costly emergency after hours service call. The next day a new board required a three hour drive. Fortunately a fan powered propane heater kept our pipes from freezing.
I fixed my problem by ordering a new control unit (model 56) from IAQSOURCE. Installing the control unit took a few mintues, and once the new control module was installed, I've had no more problems. The URL is as follows: http://www.iaqsource.com
