Question about AT&T Cell Phones
I accidentalluy put my cell phone into my dryer for 20 minutes with my (dry) coat. the battery detached itself from the phone in the dryer so that when i took it out i had to put the battery back on. a simple task but my phone wont turn on. is there a way that i can get this to work? should i let my phone rest for a while or something?
    Scholar:
  • 129 Answers
Intense heat will damage or destroy the Battery. Also, heat will damage or destroy the Liquid Crystal Display (LCD) by melting the crystal.
Try the phone with battery charger connected. With Charger connected and powering the phone, try to turn on. The Back light is usually driven by LED s which are robust and can sustain the Dryer heat.
If the phone back light comes on, the the phone electronics is probably OK and will still work as a phone.
The Battery can be replaced, but there is no easy way to replace a bad display.
So, Power with Charger, look for light, try dialing without display.
  • If above suggestions fails , then its better to approach an authorized service center
Hope this helps.
Posted on Mar 15, 2010
6ya staff
SOURCE:
Left phone in rain for 20 min. Very little moisture in phone and water marks untouched, but touch screen non responsive. Hard reset had no effect.
A phone in the rain for 20 mins is way more than enough time for it to get water inside. There still may be hope, but odds are against it. Turn it off now and take the battery out. Get a hair dryer and blow dry it for about 20 or 30 minutes. Don't over heat it, but keep it consistently hot the whole time. Let it cool and try it again. There is normally a white dot somewhere under the battery. If that dot has turned red, you definitely have water damage that voids any warranty you may have had. Good luck with the dryer.
Sep 03, 2015 | Cell Phones
My e5 got little wet and now am having trouble with itz display!!!!!
how wet is a little wet
you still might have some moisture in the phone dry it out completely
use a hair dryer but dont get it too hot
you might have to use the hair dryer every 10-20 minutes depending on how hot it gets
you might even dismantle the phone to dry it out
hope this helps
Dec 10, 2011 | Nokia E5 Cell Phone
Phone is wet what should i do
First, take off the battery from the phone and take a hair dryer and dry both the battery and the phone about 20 minutes. Then, DON'T PUT THE BATTERY BACK go to the cell phone service center.
May 18, 2011 | Samsung SGH-C180 Cell Phone
My kenmore dryer runs for 5 minutes and shuts off. I have replaced the door switch and ran the dryer with the vent hose detached. Still not working
Try this: Find the sensing bars and clean em with 409 or windex. They may be coated with stuff from dryer sheets. This builds up a moisture barrier. The machine does not FEEL the wetness from the clothes and assumes they are dry.So it shuts down after 5 minutes. Let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 21, 2011 | Dryers
My electric dryer shuts off after about 20 minutes of drying
ok sounds like you are using dryer sheets,,,dryer sheets coat the automatic dry sensors and fool the unit into thinking the clothing is dry,,,,replace the sensor or try to clean it if possable with a green scrubbie,,,,also try the time cycle it dose not use the sensor.......www.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
I accidentally put my cell phone in the dryer for 20 minutes with my coat (my coat was dry). the battery was wasn't connected when i retreived my phone but when i attached it the phone wasn't working. is...
  • If above suggestions fails then ,please approach an authorized dealer / service center .
Hope this helps.
Mar 15, 2010 | Lenmar Lithium-Ion Battery for Select LG...
Phone won't turn on
Get a blow dryer and use that for about 3 to 4 minutes, IF that doesn't work put your phone in a bag of rice it should dry it out.
Apr 24, 2009 | Nokia N95 Cellular Phone
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Cell Phones Logo
80 people viewed this question
Top AT&T Cell Phones Experts
Ekse
William Alequin
Vincent G
Vincent G
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
