Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How to install the drivers for my Konica Minolta Bizhub C350 to my PC
Posted by bevisenlike on
toddmat
  • 44 Answers
Go here:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=bizhub%20350
Pick set of software that matches your OS, such as windows XP.
Follow install instructions and the printer will show up in your PRINTERS AND FAXES control panel. You can then go into that and set the options you may have, such as the stapler/booklet maker.
You will need to know the printers IP address, such as 198.162.1.10
prior to running installer.
Posted on Mar 15, 2010
5 Related Answers
Anonymous
SOURCE: konica minolta bizhub c350 installer for mac
You have to have a fiery unit (external controler) to use the C350 With a Mac because the c350 dosnt come with appletalk in the software. IC-401 Is the model number of the controller you will need to connect the c350 to any kind of mac for printing / scanning.
Posted on Apr 29, 2010
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: I need the drivers for
www.mykonicaminolta.com search this link for any drivers.
Posted on Nov 03, 2010
herminio_hal
Herminio Halili, Jr.
  • 210 Answers
SOURCE: I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
Posted on Jul 09, 2009
Anonymous
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
mike roark
  • 158 Answers
SOURCE: How do I install Konica
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Posted on Oct 24, 2009
Steps to install c350 and the drivers
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Jul 08, 2015 | Konica Minolta Bizhub C350 Digital Copier,...
Konica Minolta c350 printer driver install
You need a Ethernet cross over cable. plug that into computer the other in to copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 06, 2014 | Minolta Office Equipment & Supplies
Konica minolta c350 doesn't working in windows 8
Download the PS version for printer driver on to konicaminolta support.
Mar 22, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub c350 installer for mac
Mar 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I have a konica minolta bizhub c350 network printer / scanner -- how do i use the scanner?
hi U must have the driver see [konica minolta sit support an driver serch for TWIN driver ] will help U
Jan 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta c350 troubleshooting
see konica minolta sit support and driver put ur c350 and downlode
Nov 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
May 11, 2009 | Minolta C350 Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
887 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
