Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I have somehow managed to put my hotpoint aquarius into test mode
I have somehow managed to put my hotpoint aquarius wd640 washer dryer into ''test'' mode. How can I get it out of this? Thank you very much!!!
Posted by zoe2663 on
electronic & computer repair& servicre
  • Hotpoint Master
  • 12,061 Answers
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Posted on Mar 15, 2010
  • marek_bohatk Dec 09, 2010
    Thank you very much that is so helpful
Wd640 stuck on test
hold both buttons in until dsiplay clears
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint wd640 and i cant get it out of test mode any ideas?
trn main dial to empty drum icon
press start/cancel button and on/off button together then switch off at mains and leave for 10 mins
got this info off hotpoint themselves and it works for me
Jan 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint hd640 washer/dryer
ok make sure of a couple things waters on settings not in standby mode or safe mode clean all traps and filters
circuit breaker not trippin out or had been tripped out
May 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpont washer/drier
if you accidently push the on/off and start buttons together, this put the appliance into a test/demo mode. to cancel it you just need to push the on/off and start buttons at the same time and "d off" should be displayed on the screen and it should now work as normal
May 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Washer Dryer
I had a similar experience.  I had to try a few times - it has to be EXACTLY together and then the magic "doff" shall appear and save the world.
Dec 19, 2007 | Hotpoint Aquarius WD640 Front Load...
Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
378 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
