SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
SOURCE: vulcan bonair evaperative cooling unit will not
If shut down at end of season by air con person may be switched off in roof unit. just remove one side and should have switch in unit usually near pump
Posted on Nov 01, 2009
SOURCE: Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
SOURCE: I have a bonaire vulcan
Please check if the timer was set properly or it was been set to sleep mode. You may also try to disconnect the plug from its outlet to reset everything, then plug it again and turn it ON.
Posted on Nov 03, 2010
May 10, 2014 | Heating & Cooling
Feb 17, 2014 | Mastercool 67471 Evaporative Cooler Air...
Nov 03, 2010 | Mastercool 67471 Evaporative Cooler Air...
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Nov 16, 2009 | Heating & Cooling
Nov 01, 2009 | Mastercool 67471 Evaporative Cooler Air...
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Feb 16, 2018 | Heating & Cooling
281 people viewed this question
