Question about Refrigerators
Refrigerator compartment is warm around 20 centigrade and have foul smell. Freezer is OK.
  • Anonymous Mar 21, 2010
    The fridge with solid ice formation suppose to defrost it automatically. I could not understand about the build up of the ice around the evaporator coil. I am now monitoring both fridge & refrigerator which shows -15C and 3C respectively. Thanks for your earlier solution posted
Rene J Solis
    President:
  • 1,796 Answers
Hi!!
Have you checked the temp. controls? Sometimes they get moved by accident.
The next thing to inspect is the freezer fan motor. This motor is the one that blows cold air from the evap. in the freezer to the fridge compartment.
If both things are OK, have the fridge serviced asap.
Good Luck!!
Posted on Mar 15, 2010
Testimonial: "Thanks.I managed to open the plastic cover inside the freezer compartment and it is full of ice all over the evaporator pipes & fins. It is OK now"
  • Rene J Solis Mar 21, 2010
    I'm glad you solved your problem.
    One more thing, set freezer termostat around 2 - 3 (to keep it from freezing up) and fridge control around half way to let plenty of cold air in. Adjust as necessary every 24 hrs. to let system stabilize.
Amana refrigerator making foul smell
Is it getting as cold as usual? The refrigerator will not usually create a smell but warming food will.
Sep 23, 2013 | Amana ABB1927DE Bottom Freezer...
Freezer is blowing and staying around 20 degrees and refrig is warm?
If you mean the rest of the refrigerator is warm, that means the fan that circulates the cool air from the cooling coils around the freezer compartment is broken, you'll need to send it in for repair.
Mar 06, 2011 | Refrigerators
Freezer 20 deg --fridge 55 deg fridge not cooling
Check compressor working and also with correct pressure. Keep arm in condenser coil. If you feel warm, check freezer to hear slight whistling sound. If not short of gas or gas leak. If warm and no whistling sound means, system chocked. Release all gas and flush out system. Vacuum and do gas charging. Thermostat setting must be 3 to 5 degree Centigrade.(37*F to 41*F). Thanks.
Feb 04, 2011 | Refrigerators
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Foul smell in refrigerator... have completely cleaned both freezer and refrigerator compartments... am stumped...
best suggestion is to completely go over it with bleach/water solution and maybe turn it off leave it open for a few days.see if that helps...
Jan 17, 2010 | Kenmore 5522 / 655224 / 55222 / 55229 Side...
Refrigerator not cooling but the freezer ok
Sounds like the thermostat or control mechanism is broken in the fridge compartment. You willneed to call a service engineer to fix it or risk getting ill.
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
