Small fridge not cold enough causes
(1.) Restriction in the freon dryer / capilary tube
(2.) Loss of freon / coolant due to pin hole type leak
This also does not rule out the compressor as a suspect. Do you know if the compressor stays running for an extended time? If not there can be a problem with the (3) PTC relay, (4) the thermal overload or the (5)run capacitor.
If the compressor is running for an extended time but just not reaching the correct temp and then automatically cycling off (6) the temp control can also be the problem.
And finally the last possible cause can be a (7) dragging compressor rotor i.e. not running full speed.
There is not and instant "this is the problem" solution for a not cold enough symptom unless this is a frost free unit... then we need to discuss defrosting problems.
Thanks for using FixYa.
Kelly
