Question about Alphasonik Mayhem PSW912 Car Subwoofer
Which speker box should i use for alphasonik
Which speaker box should i use for alphasonik mayhem
Posted by donavin212 on
Morne Olivier
    Guru:
  • 257 Answers
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches
Posted on Jun 08, 2010
Alphasonik 12 inch series 800 is not working. I'm not sure what's wrong with it
Have you tried to hook up another sub (spk) to the amp? Or just wire it to a stereo to see if it works? single voice coil or dual?
Aug 15, 2016 | Alphasonik Car Audio & Video
Trying to 1ohm my sub for a 2 channel brideable amp
you can only do that if your sub has a switch on it otherwise just hook it up and pound it
Sep 08, 2011 | Alphasonik Mayhem PSW912 Car Subwoofer
Sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
i have this problem too,sbs 2.1 370 speaker problem is only when we coonect speker to right side. Left side not working
Nov 21, 2010 | Creative Labs SBS 370 Computer Speakers
Where can i find a wiring diagram for these subs??
Here is a link for wiring speakers:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Your speaker is a DVC so follow the Dual Voice wiring as it is universal set up.
Sep 19, 2010 | Alphasonik PSW112C Alpha 100 Series 12"...
Recall
they can be easily blown/burned out
Jun 03, 2010 | Alphasonik Mayhem PSW912 Car Subwoofer
Which is the size of the box just for one PSW912 to mount
I used to compete with these subs, and found that for street beat 2.7 cu ft ported tuned at 38 hz was the best for this sub.
If using for max SPL your tuning will be much higher, like around 55 hz. But that all depends on the vehicle.
Aug 09, 2009 | Alphasonik Mayhem PSW912 Car Subwoofer
Is the ALPHASONIK PBAT10 bass tube a good product
If your limited with space they will do just fine if your looking for really stong bass don't look at bass tubes get a sub enclosure look at the lanzar opti 1232d I have to of these and they are sick go to this site and check it out http://www.lanzar.com/itempage.asp?MODEL=OPTI1232D
Jun 10, 2009 | Alphasonik PBAT10 Car Speaker
I need to know the enclosure specs for the PSW615 alphasonik subwoofer... need volume for vented enclosure
Hello chetdyal,
For a ported enclosure with room for a port, you're going to need a box with about 3.0 CuFt internal volume. Using 3/4" material and outside dimensions, this translates into a box 25"(w)X18"(h)X15"(d) giving you 3.03 CuFt allowing a little volume for the sub and port displacement. For a tuned frequency of 38Hz, you'll need a rectangular port 2"X6" and 4.6" in length. A round or cylindrical port for the same tuning frequency would be 4" in diameter and 4.9" in length. Increasing the port length will lower the tuned frequency.
There's excellent volume and port calculators on The12v.com web site. I'd recommend that you browse some of the "box-building" information before you begin your build. The DIY Subwoofer site also has some great resources.
Keep in mind that a ported enclosure will tend to produce the loudest bass notes very close to the tuned frequency. So tune it higher or lower according to the music you will be playing.
Hope this helps.
Jun 08, 2009 | Alphasonik PSW615 Car Subwoofer
Problem about sound
i am using same configuration with 5.1 creative speaker with good sound. in 5.1 sound system there are 2 seperate jack for left and right speaker. you attach one adopter having 2 in and 1 out point.The jack is 'Y' shaped. that will solve ur problem.
Nov 25, 2007 | Intel D915GAV Motherboard
Alphasonik Mayhem PSW912 Car Subwoofer Logo
303 people viewed this question
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
