Question about Zenith Z25X22S 25" TV
DVD viewing shows in black and white
I have a 1997 25" Zenith TV. Model # Z25X22S. When I choose the TV/Video button to view DVD's, the picture shows as black and white with horizontal scrolling lines. What could be the issue here? I also have a convertor box on this TV. Thanks in advance for any suggestions.
Posted by d_art_tist3 on
Girish Bhat
    New Friend:
  • 106 Answers
You have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Posted on Mar 15, 2010
Zenith 25" model z25x22s has hardly any green
Check the green output section circuit at the video output card for any loose soldering. This card can be located at the neck of the picture tube itself, will directly plugged to it. You can pull it out of it for repair. Re-solder all the suspected solder terminals there.
If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 16, 2013 | Televison & Video
Same crazy problem here! I have a converter box and can't figure out how to get the dvd to work. I managed to get a b/w picture to come barely come in (has rolling horizontal lines). What channel is it...
The converter box simply installs between your Antenna and your TV (tune to channel 3 or 4) http://digitaltips.org/docs/FlosTips.pdf
A dvd that does not Record is designed to simple install into a separate Input connection on the TV (do you have a VCR/DVD combo?)
Do you have an older TV with only one "Input" for a cable connection? (no Red/Yellow/White Inputs) if yes you may need to take a trip to Radio Shack
Mar 12, 2010 | Zenith Z25X22S 25" TV
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Zenith tv, video retrace lines.
how is the 200 volt supply to the video output transistors??
measure the collector voltage of the video output transistors with the crt board on and off the crt. if voltage goes up when crt board is off then crt shorted
Apr 28, 2008 | Zenith Z25X22S 25" TV
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Hooking up a dvd player
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Sep 17, 2007 | Zenith Z25X22S 25" TV
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
