well it could be a couple of problems depending on where exactly the water is coming from ill give you a troubleshoot for each and you can decide which is best depending theese are all directly from maytag
My refrigerator ice maker's fill tube leaks. How can I stop it?
First, check to make sure the clamp on the tube is tight.
Then, check to make sure the fill tube inside the freezer at the ice
maker is not frozen. If it is, try using a hairdryer to thaw the tube.
Finally, check to see if the water pressure is too low. It should be
at a minimum of 20 psi. For more information or assistance, please
contact an authorized Maytag service provider.
My refrigerator's water dispenser is
leaking. How can I stop it?
Try checking the connection at the bottom of the freezer door to
ensure the nuts are tight.
Next, check lines going to the water reservoir to make sure the
connections are tight. You'll find the connections in the back of the
unit behind the black sound damper.
There's a leak underneath my refrigerator.
What's causing it?
There are a couple of things you should check. First, make sure the
tubing is tight and not cracked.
Then, check to make sure the drain pan is in place and not cracked or
broken.
If these tips don't help you find the source of the leak, please
contact an authorized Maytag service provider for more information or
assistance.
There's a leak inside my refrigerator.
What's causing it?
First, check to make sure the door is closing and sealing properly.
Next, check to make sure the fill tube connected to the ice maker is
aligned properly and isn't letting water splash.
If none of these steps corrects the leak and you discover the water
is coming from the fresh food sealing, you'll probably need to have the
defrost pan checked. For more information or assistance, please contact
they are all pretty much along the same lines hope your eyes aren't bleeding from the laundry list here but it seems you should check the connections from the hose and the psi it sounds like your problem is related to a lack of pressure which would explain why water is not coming out and seeing as you have a visible leak would lead me to believe the pump is working correctly
Hope this helped
sorry if its long winded
please leave feedback
Robb
