Question about JVC KD-SX770 CD Player
Need help setting time on jvc kd-sx770 - JVC KD-SX770 CD Player
Posted by cwade1960 on
Anonymous
    New Friend:
  • 44 Answers
Turn off the stereo then ull see the time only on ur set then u can set up!
Posted on Mar 14, 2010
I NEED TO CLOCK SET
Please go to the link below page 20 will tell you how to set the clock.
http://resources.jvc.com/Resources/00/00/98/GET0019-001A.pdf
Apr 02, 2011 | JVC KD-SX770 CD Player
I don't know how to set the clock
If you follow this link it will take you to clock settings on page 20. It will be easier than me trying to send it all here. May be an idea to print the whole manual off really?
Good luck with it and please feel free to remark if suitable.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/257/257KDSX870.PDF
Mar 29, 2011 | JVC KD-SX770 CD Player
CD Player does not work. Can CD player be repaired?
If it is possible to repair only habria that to check it to repair the fault in general always checks what is the module of CD or the lens
Feb 03, 2011 | JVC KD-SX770 CD Player
I just purchased front speakers for my jvc kd-sx770. the connection to the previous fronts were cut by the previous owner of the car. i cannot find a wire diagram and just need to know what colors to...
front left negitive, white with black stripe front left positive, white
front right negitive, grey with black stripe front right positive, grey
I hope this has helped you and please dont forget to rate my solution.
cheers
Jan 15, 2011 | JVC KD-SX770 CD Player
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
Dosent play burnt cds
Try to burn cd in 4x speed burn. Or try to burn the audio as CDDA format at lower speed burn.
Crackes usually appears when burn the cd at high speed.
Pls. leave a comment
Apr 10, 2009 | JVC KD-SX770 CD Player
No audio output from jvc cd receiver kd-sx770
The internal amplifier is at fault.
This will need to be repaired by a electronics repairman.
There is no end-user fix.
You may choose to, instead, use the RCA low level outputs and install a dedicated amplifier to power your speakers.
Verify the fuses on the radio are good, and that there is not a blown speaker causing the internal amplifier to shut down.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | JVC KD-SX770 CD Player
Kd-sx770
You can buy it from pacparts.com
Dec 08, 2007 | JVC KD-SX770 CD Player
JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
May 18, 2007 | JVC KD-SX770 CD Player
JVC KD-SX770 CD Player Logo
175 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
