Question about Palm Zire 31 Handheld
I have Palm Zire 31 and the stylus is not responding to the touch screen so I can not Hot Sync my device since I must confirm by hitting this button. Any sugestions? I tried the hard reset and soft reset and no luck....
    New Friend:
My palm zire 31 is frozen...i can not turn it off...i can not navigate any where on it.....please help
Posted on May 01, 2010
6ya staff
SOURCE:
I would like to give my Zire 31 to a friend but need to erase all my information from it. How do I do this?
Do a HARD RESET on your PALM ZIRE 31.
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
  1. Press and hold the Power (on/off) button on the front panel of your device.
  2. While holding Power, use an unfolded paper clip, or the reset tool at the tip of your stylus. Gently press and release the RESET button inside the hole on the back panel of your device (where's the reset hole?).
  3. If you see a progress bar (see below), keep holding the Power button.
  4. Next, the Palm Powered screen will appear. Release the Power button when you see it.
  5. You'll see a screen that asks: Erase all data? YES = "up" button NO = any other button. Press UP on your 5-way navigator to complete the hard reset.
Jun 28, 2011 | Palm Zire 31 Handheld
How do i perform a hard reset on my palm pda
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
May 26, 2010 | Palm Zire 31 Handheld
About 1/2 of he time now, my Zire 31 has problems
Either the digitizer is failing or you have a protective screen on it.
I'm not sur eif Palm is still supporting these of if they have changed policies. It used to be a set fee say $85 to fix or echange. If they still do this. then I would find out if they apply the $25 against the repair fee. You can also send it in to several pda repair places who wil fix it for a reasonable fee.
A Tx or Lifedrive is a better palm but can be worth much more. You can find those used all over and may be the way to go to upgrade if you want to save a few $
Mar 31, 2010 | Palm Zire 31 Handheld
How to sync palm data with Itouch? I have all my contacts & calendar on my Palm Zire. How can I get the same data over to my I touch in a Windows XP environment ?
You can sync to Outlook on the PC and then get the Outlook data onto the iTouch. If you have a newer PDA, It's install CD has a Sync options menu item where you can switch between Palm Desktop and Outlook. If you no longer have the original install CD or have an older device Pocket, Copy from Chapura.com It will move the Palm Desktop records to Outlook.
Mar 08, 2010 | Palm Zire 31 Handheld
New computer running Vista won't recognize Zire 31-no driver?
Have you installed PalmDesktop to your new computer yet?
There is no Windows driver for the Zire 31, but you will need Palm Desktop before you can sync.
I still have a Zire 31 in a box in the garage, and I'm happy to dig things off of the CD if you need anything, just use "add comment" in the top right corner there.
Jan 11, 2010 | Palm Zire 31 Handheld
It worked fine for a few years then my computer
Reinstall Palm Desktop and or update it.
Jan 07, 2010 | Palm Zire 31 Handheld
Zire 71 screen does not sense stylus input -- even after performing a reset.
HI,
Try doing a hard reset. This will erase everything on your zire and restore it to brand new settings. To do a hard reset make sure you have everything backup on your palm desktop. Here are the steps for the hard reset:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus2.gif.
2. Continue to hold them both in until you see the Palm2.gif logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync. It should clear up your problem. Best wishes.
Oct 10, 2009 | Palm Zire 71 Handheld
ZIRE: FROZEN THEN WHEN RECHARGED LOST ALL INFORMATION
I had exactly the same problem. I Hot Synched it with my computer (Ignore instructions for load cd) and everything returned as normal. Since this episode, I've learnt to hot synch more often than I was doing.
Jan 17, 2008 | Palm Zire 31 Handheld
Palm frozen - Won't Move
o at the back of ur palm is a reset button just press it and it should be fixed
Sep 07, 2006 | Palm Zire 31 Handheld
Palm Zire 31 Handheld Logo
342 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
