When i turn my xbox 360 on it will play the sounds but no video
When i turn my xbox 360 on it will play the sounds that it usually makes but the screen will stay black. i tried the towel trick last night but no results whats wrong with it and how do i fix it?
Re: When i turn my xbox 360 on it will play the sounds...
If your using the hi-def cable(red blue green) check that its switched to either standard of hi-def. Also if your using the hi-def cable it wont work if u have the white head in the same time as red blue green! Hope it works for you!
Check to make sure the video selector switch on the video cable is set to proper position according to your type of tv. (TV or HDTV)
Unplug your cables and then plug them back in again.
You can also turn on your Xbox using the controller. As soon as it turns on hold in the right trigger and press the Y button. This will reset the video system settings.
It may be possible that you have a bad video cable but I doubt it.
If none of the above works you'll need to call xbox support to have your console repaired especially if it's still under warranty. If it's still under warranty, (under 1yr old for this type of problem) Microsoft will repair it for free.
While Xbox 360 is a popular video game console for many game lovers, Microsoft also provides large space up to 250GB for making Xbox 360 more than a video game console. Most users many take Xbox 360 and a part of the home entertainment with the Xbox Live Marketplace and home movie collections. <br /><br />Xbox 360 Supports video files in Windows Media Video (WMV) format, ASP, H.264 and MPEG-4 media in .mp4 format. If you downloaded MKV videos from hd-torrents.org, you need to convert the <b>HD MKV videos to Xbox 360 WMV</b> before playing them. Aunsoft Video Converter is the best HD <b><a href="http://www.aunsoft.com/video-converter/">MKV to Xbox 360 Conversion</a></b> on Windows to make it easy to play WMV on Xbox 360 via DLNA. <br /> <br />Follow the step-by-step guide below to <b><a href="http://www.aunsoft.com/top-notch_hd-torrents_mkv_to_wmv_converter_for_xbox_360_with_dlna/">Convert and Share MKV to WMV files on Xbox 360 via DLNA</a></b>. <br /><br />Step 1. Load MKV to Aunsoft Video Converter. <br />After downloading MKV from torrent sites, just run Aunsoft Video Converter as the best MKV to Xbox 360 converter, and click the "Add" button to import batch of .mkv videos. <br /><br />Step 2. Choose Xbox 360 WMV format. <br />Click the "Format" option and choose <b>Zune/Xbox 360 Device > Xbox 360 HD Video(*.wmv)</b> as output format. The Xbox 360 video converter will convert MKV to WMV for perfect playback on Xbox 360. <br /> <br />Step 3. <b>Convert MKV to WMV for Xbox 360</b>. <br />Click the convert button under the preview window, and the MKV to Xbox 360 converter will start converting MKV torrent videos to WMV for playing on Xbox 360. <br /><br />You can easily <b><a href="http://sony-mts-converter.com/2011/07/xbox-360-dlna-convert-and-play-mkv-to-wmv-files-on-xbox-360-via-dlna/">Play the WMV Files on Xbox 360 via DLNA</a></b> after copying the video files to Xbox 360 and <b>Watch Videos on DLNA-compatible HDTV via network</b>. <br /><br /><b>Tips:</b> <br />For playing Blu-ray disc movies on Xbox 360, you can use <b>Aunsoft <a href="http://www.aunsoft.com/blu-ray-video-converter-ultimate/">Blu-ray Video Converter Ultimate</a></b> to rip and convert BD movies to WMV for Xbox 360.
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
This is usually caused by a bad graphics card on the xbox. It isn't always detected by the xbox motherboard. I'm sorry to say, but it's pretty much toast unless you can find a repair guy in your area to solder on a new vga card.
try another tv to ensure its your xbox and not tv input. also look on your av cord there is a small switch on it make sure it is in the proper position hd or tv.
