Question about Bunn VPS Coffee Maker
The water is boiling, but wont flow into the filter??
Our VPS worked fine a while ago. then we moved it. Now after putting water in and waiting u can hear and feel the water boiling but the water isnt flowing into the coffee filter. Any suggestions?
Posted by matthews_734 on
Ernest R
    President:
  • 1,618 Answers
Remove sprayhead and pour water into tank until it flows from the brew tube, then replace sprayhead and brew coffee.
Posted on Mar 15, 2010
I have an aprilia mxv 450 crosser.had for 2 years from new.i have had an ongoing problem with overheating too quick from cold,boiling over instantly after a race,even in icy conditions.aprilia put new head...
when you say boils over do you mean dumping out the over flow pipe ? have you tried new radiator cap
sorry mate it seems like you checked everything but I have seen plenty of MX bikes come in from hard race and dump half their coolant on the floor through the over flow pipe as soon as they turn engine off its nearly always the radiator cap (pressure release) is to weak when this happens
thought it worth a mention but no doubt you checked already?
Jun 18, 2011 | 2009 Aprilia MXV 45
Replaced the water filter 3 days ago, no water now. Took filter off and it had so much pressure it almost blew out of my hand. Put old filter back on and same problem. Ice maker works fine.
the frig uses a dual valve and the foutain water is filter water the water line is frozen ( i think ) and if you warm up the freezer it will flow . try it and we'll go from there .. freezer tempt should be around 0 to 5 deg . also ck the water blater behind the crisper and see if its frozen and veg will also freeze . this may be caused by a bad dampner control between the freezer and the fresh food side. mm hope this helps . feed backk pls ..
Nov 08, 2010 | Hotpoint HSS25GFP Side by Side...
I have ahayward H1001D1 above ground pool heater running on nat gas has worked for 3 seasons with no problems last week heater started to make banging sound as if it was rapid cycling ichanged filter...
If your external by-pass is closed almost all the way then it will be your internal by-pass. You find this assembly inside the water manifold at the side of the heater. Part should be about 70-80 bucks.
It is suppose to regulate the water flow so it has time to heat but not boil. Yours is probally missing the control disc and letting all the water flow past the heater so the water in the heater is boiling and that is the banging you hear. Good luck.
Sep 04, 2010 | Hayward Pool & Spa
I just get bunn VPS it is and work very good
The switches are for the "warmers" only. The brewer has a reservoir the keeps water hot and ready for brewing. When it is not re-heating water (after brewing) it has a "keep warm" heater that is low voltage and keeps it ready to go.
May 16, 2010 | Bunn VPS Coffee Maker
Purge water filter on refrigerator
the water valve may be your problem,it is a dual valve system one valve for the icemaker and one for the water dispensor.
Jan 22, 2010 | Refrigerators
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
Krups FME2 will not flow water.
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Jun 29, 2008 | Krups FME2 Coffee Maker
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Bunn VPS Coffee Maker Logo
252 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
