Question about Keurig Elite B40 Coffee Maker
Power switch light is flashing no other functions are working. What is the resolve to this problem?
Posted by normcjr on
Anonymous
    New Friend:
Posted on Mar 15, 2010
HELLO MY kdf-e55a20 tV IS NOT WORKING. THE GREEN LIGHT FLASHES 6 TIMES THEN IT FLASHES RED 6 TIMES
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The Lamp light blinks when the Lamp requires replacement.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the power light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
This indicates that there is some kind of audio problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 11, 2011 | Sony KDF-E55A20 55 in. LCD Television
My standby/timer light is flashing and will not turn on.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Jun 02, 2011 | Sony KV-27S66 27" TV
Standby time light on and keeps flashing
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
KDF 50E2000 WONT POWER UP POWER LITE BLINKS RED 3 TIMES THANKS
May 12, 2011 | Sony KDF-50E2000 50" HDTV
TV turns itself off and power light flashes green
May 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kdl-52xbr4 5 blinking standby lights
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
Green blinking light
Oct 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
4 fast blinking lights
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Keurig Elite B40 Coffee Maker Logo
1,467 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Vincent G
Vincent G
Colin Stickland
Colin Stickland
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
