Gateway FPD1760 17" LCD Monitor Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This monitor is great. Just recently, after 3
This monitor is great. Just recently, after 3 years of use, the screen is tinged green. It'll go back to normal, but is staying green more and more. Is it dying?
Cherwoh
Level 2:
Scholar:
  • Expert 66 Answers
  • Posted on Mar 15, 2010
Cherwoh
Expert
Level 2:
Scholar:
Answers
66
Questions
0
Helped
16368
Points
184
It seems so.
1. Change the monitor cable and see if this still happens
2. Attach this monitor to another PC and see if this still happens
If it is still happening, then yes, it seems that it is failing.
My Compaq Computer monitor Model PE1212 has a very dimme screen i have put Brightness to 100% but is still not working. what should i do?
all old monitors are dead now, yours only dim, 15" LCD relic
Compaq Monitor PE1212 Used A 1024 x 768 LCD 15" year 2002 made
all had, CCFL back lamp tubes.
all are bad for::
  1. Dim
  2. dead
  3. 1/2 tubes bad, 1/2 screens
  4. blinks or strobes
  5. yellow tinged white screens.
  6. works only hot or cold. or intermttant.
what;s to like about CCFL, zero
buy 2010 and newer monitor with LED back lamps.
Crt monitor gradually develops a yellow tinge after being turned on for a few minutes. It fluctuates annoyingly. It is about 4 years old. It is a Samsung SyncMaster 753DFX Crt monitor.
CRT monitors have three color "guns" in them - Red, Blue, & Green. If one of them is starting to go south you will have a tinge as you describe. To make sure it's the monitor, try connecting a different monitor. If the monitor is the problem, it's not worth fixing. Replace it.
If, after changing the monitor you still have a color tinge, you have a problem with your video device in your PC and you need to have it checked out by a PC Technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
1helpful
Acer X193HQL LCD Monitor Colour Problem
Hello Sales, hi, try to reconnect the VGA cable from the PC, and wiggle it a little and see if the green tinge thing disappears on screen, if it does there are loose contacts, you can also try to replace you VGA cable, see if it solve the color problem.
2answers
Pink color
check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Screen is tinged yellow
It sounds like you're going to need a new VGA/DVI cable. (from PC to monitor)
I suggest you try another one, then post back here if it doesn't fix the problem.
I hope this helps,
Yannick.
Colors always changing
now that is one wild post.?
NO PC told
no OS told
no what app shows wrong colors
what does wrong mean? we can not see it.
what are you doing, with the PC, and application of some kind or just windows screens wrong.
is this a artist point of view , for Publishing in perfect tints?
does VA2026w fail on 2nd PC?
old monitors (trashy) have CCFL back lamps
and go yellow tinged for white, and yellow added to other colors are trash. too.
let me C 14 carbon date this MON.
2007 made and is CCFL lamps and all are bad now
or yellow dog tinged or changes hot../cold or random.
time to get a real monitor called LED 2010 or newer.
2007 are junk,
the CCFL will go dead next. all do.
here is what mine looks like, then,.... long ago.
just like this.
https://www.pcdied.com/monitors_and_screens/yellow-ccfl.JPG
pure trash monitors, all brands that year or older
2010 is the cusp year CCFL > LED
starting with big screens to small.
so 2011 is best year up;.
2010 some are some not.
2007 is junk,
Monitor won't turn on without help.
Do you have a second monitor or can you borrow one to check if the fault lies with the monitor or the PC?
If the monitor is at fault then there is not much you can do yourself. I suggest you contact Dell and get them to replace it under warranty. Most LCD monitors have a 3 year warrantly, at least they do in the UK.
cheers
I have an Acer screen, about 1 year old. For some strange reason my screen has come up with a yellow/green tinge to it. Not easy on the eyes. Can I fix this problem myself or is it something that an...
hello wayne,
If this is a CRT screen. . then this applies.
if you have discoloration on your CRT tube monitor (due to a magnet being place near the actual tube), (i.e Speakers)
Most new Monitors have a magnetic degaussing circuit built in the Click the Menu button on the monitor and look for "Degauss". If that doesn't fix the problem.
or check this out for more reference: metacafe link
good luck,
DjEnigma
1helpful
Speakers - no volume
double check that the speaker wire (green) is connected in the back of the monitor and into the back of your pc into the green connection, if it is and there is no sound you can always use a seperate pair of speakers, as it will be cheaper than repairing the monitor.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
