Question about Master Lock 5400d: Portable Select Access Key Storage Lock
Forgot combination to 1500id master lock how do I reset the combination now
Posted by gt6996stang on
  • Anonymous Mar 16, 2014
    Who do I reset the combination lock on my 2000 navigator if I'm locked out the truck
Maame yaa
    New Friend:
Forgotten my combination, how do I open and reset a new combination??
Posted on Feb 18, 2012
cthulhu_myto
    New Friend:
The only thing you can do is to disassemble it. There's a couple of screws with triangle shape. Those are easy to get out with a torx screwdriver. Then you need to take the one in the middle with a flat screwdriver and a hammer. Why? Because the head of the screw is cut in half, you cant turn it CCW to open it, only CW. Give it some hits with the hammer and the screwdriver to open it. After that,open the lock, and you have to set each gear and plastic part in the home position. Just be patient and set everything in place. You have to turn some parts so everything fits right. Remember to pass the lock to "reset" position. Afterwards, assemble the lock and close it. It will be unlocked.
Posted on Mar 26, 2013
Anonymous
    New Friend:
From my understanding, you don't.  Cut the lock and buy another (and don't forget this time).
Posted on Jul 31, 2010
Where do i store my combination
I am not aware of a "Lock Box" or "storage" capability on FixYa.
If you want storage capability for free...
Google free online storage.
  1. Googledrive.com
  2. box.com
  3. dropbox.com
  4. iCloud.com
  5. evernote.com
  6. bitcasa.com
These are just a few available that are very good.
Nov 14, 2014 | Master 1500ID Combination Padlock
I lost the combination to my speed dial master lock and it is in the locked position. How do I open it and create a new code?
It's not easy to fix this problem, because these locks do not shim open and it's not obvious how a person could figure out the old combo. I was able to loosen and remove the security screws, disassemble mine and repair it. They are very tricky to reassemble and it took me hours to find the spring that was out of position. The root problem was the lock did not clear when the shackle was pushed in. Until I figured that out, it would take up to 30 tries to get it open. The security screws are Metric - so you can replace them with regular screws until you get it working. If you do open the case, there are a lot of small parts inside, including a bunch of springs.
Aug 18, 2014 | Master 1500ID Combination Padlock
How do I get it back open when it won't open to the combination I gave it?
Make sure you push the shackle down firmly to clear the lock and try the combo again. It is possible to open it by trial and error, but not easy. I have removed the security screws and repaired one, but it was tricky to reassemble. The problem with mine was a spring that slipped out of position and the lock wouldn't reset correctly. There are a lot of parts inside, so chances of getting it to work correctly are not good unless you're really good with complex mechanisms and puzzles.
Aug 05, 2014 | Master 1500ID Combination Padlock
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
Reset combination of this 1500iD.
Here is the page:
http://www.masterlock.com/pdfs/5400D_Instructions_Sheet.pdf
Sep 11, 2011 | Master Lock 5400d: Portable Select Access...
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
My friends were messing around with my 1500ID lock and changed the combination, then closed it. How can I reset it and change the combination?
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
Aug 31, 2010 | Master Lock 5400d: Portable Select Access...
Master Lock 5400d: Portable Select Access Key Storage Lock Logo
16,703 people viewed this question
Top Master Lock Locks & Locksmithing Experts
Marvin
Marvin
Lawrence Oravetz
Kelley Hopper
Are you a Master Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
