KP53S35 when tv turned on picture was disappearing for a second but sound still on , would do this 4 to 5 times in a minute,now tv does this at least 30 times in 5 mins when tv turned on , also picture slighly redder
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Testimonial: "not sure what CRT is though as you describe it,it sounds terminal. 1997 is the manual I have for this tv. at this time repair would be most desirabl"
