Question about Microsoft Xbox 360 Console
Connection to winows media failed
Connection to windows media failed
Posted by bronx24113 on
Anonymous
    New Friend:
  • 118 Answers
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imageconnection to winows media failed - networksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Posted on Mar 14, 2010
Driver disk
Windows 7 drivers are present by default. You could just connect and give windows update. If you os is original
Jan 18, 2014 | Compaq Presario SR5413WM -25928
Rear passenger window will not go up or down
weak window motor ,,have it replaced
Oct 23, 2013 | Isuzu Cars & Trucks
Hi, 2008 328xi coupe, the power window buttons on driver's door stopped working, is there a fuse?
The window operate on a circuit breaker type fuse, fi the window are working with the other buttons then its not a power loss problem, the circuit breaker hardly ever fails, also sometimes if the master switch which is the driver door switch, fails then you may not be able to operate the other windows with the other switches but not always the case, also theres a module that controls the winows, i would remove the door switch and make sure the connection is good, these switches often go bad from getting wet,just to be on the safe side there may be a fuse for the window module if that goes theen glass will not work, theres a fuse box on the right side of the dash and then there one in the truck on the right side i would check all the fuses, they sometimes use power from another system so check all fuses, good luck,
Jan 22, 2011 | BMW 328 Cars & Trucks
The rear windows have stopped working and cannot find where the fuse for it is.
this problem is caused by the body control module, the dealer will have to test the functuion of this module.
Nov 20, 2009 | 2004 Lexus ES 330
Sound drivers for windows 2002 sp3 for 945 intel s
first u need a winows update called high defintion audio driver package for winows version u r using ... install that first and update ur high defintion audio device using realtek driver
Mar 30, 2009 | Intel Motherboard
Philips GoGear SA6045/97 connection with pc problem.
You need to get the product key for Windows from your friend. The days when you can just load an OS from any CD an unlimited number of times is over. Microsoft Genuine Validation requires that you have a Product Key, and you STILL may have to call Microsoft to validate your copy, if Microsoft registers that an OS has been loaded from a single CD too many times.
-Tha Mp3 Doctor
Feb 20, 2009 | Philips GOGEAR SA6045 MP3 Player
Sound works on CD's and winows media player BUT not on you tube o
please re-install the drivers on sound card...might solve the problem
Feb 13, 2009 | Ozaki DT-500 3-Piece Speaker System...
Please help, my Averatec 3200 does not play dvds.
Try to use a dvd player software like winows media player (included in windows), just put the dvd in and it will ask about what to do, just select to play with media player and you can enjoy. (double click to put it fullscreen)
If nothing happens after inserting the disc than push start menu button go to programs and windows media player should be there somewhere, or in start menu push run and type wmplayer and than push enter. Than open the dvd with it.
Nov 23, 2008 | Averatec 3200 Notebook
Unistall Internet Explorer 8 beta 2
go to windows add or remove programms then click change winows components . then a box will apppear then mark internet explorer in that winow and click next to unistall it
Nov 06, 2008 | Compaq Presario Notebook
Lg8300 problemm downloading music
I need help transfer my music
that I buy all ready
Sep 09, 2008 | LG VX8300 Cellular Phone
Microsoft Xbox 360 Console Logo
127 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
