The 9 you see is the maximum "burst" which is (pictures made in rapid succession) and is not an issue with your problem at this time the flashing green dot is the in focus confirmation light and it's good that you are seeing this as we will use it to remedy the problem.
Diagram
Manual focus switch
Diagram here
What I want you to do is put the AF-MF switch in the manual mode
if it's already in manual mode then that was your problem switch to AF and go take some pictures. If it's in AF mode switch to MF make sure teh camera is on and look through the viewfinder at a subject say 15 feet (4.5 meters) away something that has contrast then turn the manual focus ring on the camera slowly until it appears to your ey that it's coming into focus when it's in focus the green light will come on solid, now you know what you are looking for focus an several different objects at different distances and focus manually. Now switch the lens over to AF (auto focus) and focus on the same thing but let the camera do the focusing What auto focus will not focus on in something with little or no contrast like water clear blue sky a painted wall mirror chrome glass and a few other things.
Here is another diagram to check make sure you are in the correct mode.
Diagram
Now for the focus point in the viewfinder make sure it's in the center position.
To adjust the focus point do this
Once you have the camera set to the center focus point and the correct AF mode (one shot) auto focus should return to your camera. Have fun Robert from London Ontario Canada
Thanks Obertelli
