Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
Our GE Adora Refrigerator's ice maker isn't working properly
Our GE Adora Series ice maker does not deliver crushed ice and the cubed ice only works when you shake the bin before use. Any ideas?
Posted by adarathestar on
Cool Blue Services
  • 560 Answers
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Posted on Mar 14, 2010
Ge refrigerator sise by side tfx274 ice maker only gives crushed ice and no cubes
you have bad solenoid, it is a small part next to the motor behind the ice bucket. It lifts up the arm to let the cubed ice out of the dispenser bucket.
May 18, 2012 | GE Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
My icemaker won't deliver cubes despite switching from crushed to cubes on selector, what's a guy to do
you have to take apart the complete ice maker from inside the freezer as it has to be cleaned on a regular basis to operate properly. check with your owners manual, it tells you how to clean it.the ice cube shoot is the first to freeze up & block your flow of ice. it's not hard to do. all the best.
Dec 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker only delivers crushed...cube option not working
The control board is probably bad. Replacing it might fix the problem.
Dec 31, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
My icemaker won't switch back to cubed ice. all i keep getting is crushed ice. HELP
If you select cube and hold open the door and push in on the light switch and have someone push the lever for ice you should hear a loud click this is from the selector switch in the back that engages a long brass colored rod under the ice maker if you hear this loud click you probably have some crushed ice in the crusher keeping it from switching back open the door and push in on the light switch and have someone push for cube ice it will kick ice out the bottom so dont be alarmed. (sometimes you have to do this a couple times) good luck
Aug 16, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My GE Adora side by side will only dispense crushed ice...the buttons seem to be working, as in the light comes on each button when pushed. But only crushed ice!
Turn off icemaker. Remove ice bin, empty it, rinse with warm water and leave to dry overnight.
If this did not help - check solenoid in the freezer behind the ice bin, make sure it's not stuck and has continuity. If all checked out ok, but still no cubed ice - control board or interface board may need replacement, and you'll need a professional to diagnose that.
Good luck,
Vlad
First Choice Appliance
Jun 02, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
997 people viewed this question
Top Refrigerators Experts
gbob59
Marvin
Marvin
