Question about Garmin Nuvi 660 GPS Receiver
For got my pin code
I put a pin code on my gps and i for got it i wanted to brake the lock off it
Posted by sexiichula50 on
Anonymous
  • 504 Answers
If you forgot your PIN, go the location at which you set the PIN. This will unlock the unit, and you can reset the PIN.
Posted on Mar 14, 2010
Hi I have a GARMIN WHere2 since I got a rental car from AVIS but it suddenly asked me for a PIN CODE? Could you please support me with this?
The Garmin
Lock (anti-theft feature) security feature has been activated.
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
You may want to call the rental company and ask them for the pin code.
To unlock the unit, it must be sent back to Garmin.
Aug 28, 2011 | Garmin StreetPilot c550 GPS Receiver
Tip
Lost PIN for Garmin Lock - Nuvi Series
I've seen many postings from users who say they have lost their PIN code.
For those of you that don't know what a PIN code is:
Garmin provides a feature called "Garmin Lock", which allows the GPS owner to assign a (4) digit numeric unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an un-authorized user. It was also meant to be used a a deterrent to thieves, making the GPS useless if stolen.
The PIN setup can be accessed by pressing the "wrench" symbol on the main menu (Nuvi Series). Next, press the "gear" symbol and you should see a listing for Garmin Lock.
When you set up the PIN, you will be asked to enter in a (4) digit numeric code. After you enter the 4th digit, you will be asked again for the code. This is to make sure that both entries match and that verify that the PIN that you request will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that is accessible via USB communications between the GPS and a PC. You can't clear it by disconnecting the power or disconnecting the battery or letting the battery run down. There is no jumper or switch inside the GPS to reset it, so don't waste your time tearing the GPS apart.
Now, after you set the PIN, you will be asked to set the "secure" location. This can be anywhere.... your work location, home, local gas station, school, etc. In order to set the secure location, your antenna must be up and you have to have a satellite lock. If you don't have a lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN. If you have forget your pin, all you have to do is physically go to the secure location. Make sure your antenna is up and that you have a satellite lock. When you are in the secure location, your GPS will NOT ask you for the PIN when you turn it on. You'll then be able to reach the main menu and change the PIN and secure location to something else if you desire.
If you have forgot both the PIN and secure location you are out of luck. You'll have to send your unit back to Garmin to have it unlocked. Garmin may charge you for this service.
Note: If you do send the unit back to Garmin to be unlocked and you are found not to be the original owner of the GPS and it's determined to be stolen, Garmin will contact law enforcement (they're policy on this is right on their website under FAQ's).
- Jim
http://www.sharcnet-usa.com
on Oct 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
- Jim
on Oct 10, 2008 | Garmin Nuvi 660 GPS Receiver
How can I unlock a passcoded Nuvi 265WT?
This GPS doesn't come pass code protected, that code is put in by the owner, so i must assume this is not your property.
Jun 04, 2010 | Garmin n?vi 265WT Car GPS Receiver
Nuvi® 255W Car GPS Receiver: i have a garmin nuvi 255w and its locked and need ...
I had for 2 years a nuvi 255w and its as working real good. Until one day i tried to open it up and it ask me a code pin. Witch i dont have. Ive been the only one owner on that GPS and never put any pin code on it and now just like that it want one... Grrrr that **** me off i cant use it anymore i dont have any acess anywhere exept that pin code of 4 number,. Is this possibility of update? I dont know I am the only one in that situation?
May 16, 2010 | Garmin nuvi 255W GPS Receiver
Tip
- Jim
http:///www.sharcnet-usa.com
on Oct 10, 2008 | Garmin nuvi 350 GPS Receiver
Pin number has locked up our gps
You have three options for unlocking a PIN locked Garmin:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin
Unfortunately, these are your only options as this is a security feature to prevent unauthorized use of a stolen GPS.
Jan 18, 2010 | Garmin nuvi 200W GPS Receiver
Gramine gps is locked with a pass word.
Thankfully the solution is very simple to your problem. The only way for the Garmin to accept a setting of a password is if you also define a secure geographical spot right after the PIN code setting.
If no safe place is defined, the lock will not engage and the PIN setting attempt is void. So if it is locked it means your daughter has stored a safe location as well (you just click ok so it is easy also for a 3-year old).
At this geographical spot the GPS unit will be unlocked, and you will be able to change the PIN code to your liking or remove the lock.
So all you need to do is to recollect the specific geographical place your daughter may have played with your GPS, bring it to that place and switch it on: no PIN code is asked for when you found the correct spot. You may need to wait a few minutes for the unit to locate satellites, then it should unlock.
Jun 03, 2009 | Buck BENNETT DVD GARMIN NUVI 750 760/770
Child put in random code and locked nuvi 260 gps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you can remember the PIN Code previously set on your device you will be able to change the Pin on your device easily. You can change the PIN on the unit by doing the following:
All Nuvi's excluding 3xx and 6xx
  1. Turn your device on
  2. Touch Tools
  3. Touch Settings
  4. Touch Security
  5. Touch On/Off under Garmin Lock
Within this section you can add or change a PIN.
When the Garmin security lock is set it locates the units current GPS location.
If you are trying to change the Garmin Lock and are not within the same location to where the Garmin Lock was set you will need to revert back to this GPS position.
Once at this position you will not be prompted to enter the PIN Code when starting the device up and can change the code as you please
Mar 14, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Naveman PIN 570 gps receiver problem
i get the "waiting for gps" message if the gps unit is sending data to the main unit, but no satellite signal is found.
does the unit have sky view?
Sep 16, 2008 | Navman PiN 570 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
202 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
John Egan
John Egan
Are you a Garmin GPS Expert? Answer questions, earn points and help others
