Question about New Bright Toys
We got a New Bright Great American Express Denver RR Train Set (runs on batteries) from garage sale. No instructions. There are two switch pieces, 4 straight pieces and 10 curved pieces. We cannot figure out the layout. It doesn't meet together in an oval. Are we missing pieces?
Posted by creelj on
Anonymous
    New Friend:
Switch pieces on opposite sides, one straight piece on each side of switch piece, then 5 curved pieces each end.
Posted on Dec 19, 2010
Anonymous
    New Friend:
You are missing 2 curved pieces. There should be 12 curves, 4 straights and 2 switches.
Posted on Nov 24, 2010
Where to put batteries in wintersville express no 182 trains set
Buy a brand new one with instructions herehttp://aeif.scalemodel.net/fsid.aspx?id=131633602115&sid=2&c=487
The batteries have to be in the locomotive, and I would expect a removable door underneath or from the rear of the loco.
Nov 29, 2012 | New Bright Small Holiday Express Train
I have a great American express smoking engine train by new bright. The train will not start, we are not sure where the on off switch is. Please help!
Ours is a really old model, but the on/off button is located on the second car (coal car) towards the very front. It's red on our set. I am looking for help on the smoke part. I can't remember what we're supposed to use for that.
Dec 24, 2010 | Toys
Hi having trouble with our new bright musical holiday station electric animated train set...very frustrating as one of the train tracks broke off a little part so no matter what my husband tries to do the...
Yes, additional track is available from several places, such as Hobbylinc.com, and TowerHobbies.com. At this time, just after Christmas, they are out of stock, however. Walthers.com has them in stock (1-4-2011). You can find extra track on sale on eBay, as well. Be sure to get the track with the brass covers, as New Bright sells battery powered trains that use bare plastic track, which will not work with the 384. A Google search will turn up more sources.
Dec 12, 2010 | New Bright 384 Holiday Express Animated...
Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Dec 18, 2009 | New Bright Small Holiday Express Train
I have a new bright animated holiday train from a garage sale and I think I am missing a power cord
You should have a 3 pieces to provide power....
1. A track connector box. Looks like a "T". It slips under the track to make the track power connection. The transformer plugs into it (2 pin Molex type connector) and the command console (has an RJ11 telephone jack type connector on it)
2. A large square transformer. One end plugs into the wall and the other into the track connetor box.
3. The Command Console. Has the on/off button, forward, reverse, mute, sounds and speed contol on it .. has a connector that looks like a telephone plug.
Unfortunately... DO NOT look to New Bright for missing or non working parts. New Bright does not offer repair or replacement parts for thier products. :-( ....
Dec 10, 2009 | New Bright 384 Holiday Express Animated...
I bought a new brighton toy christmas train set at a garage sale. the jert told me it worked. the music will play and the engine head light comes on but the engine will not run. are there replacement...
If says 187 on the box, check out this solution:
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
May 17, 2009 | New Bright 181 Toy Christmas Train
Toys Logo
2,025 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
gerry bissi
Marvin
Marvin
Are you a New Bright Toy Expert? Answer questions, earn points and help others
