Frigidaire FMT148GP Microwave Oven Logo
Question about Frigidaire FMT148GP Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
Frigidaire FMT 148GP Microwave oven. Turntable does not rotate although Turntable On button is activated
Posted by tferlet on
Anonymous
  • 1,768 Answers
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Posted on Mar 13, 2010
Fuse location
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. However, if your microwave does not heat, you may possibly have a faulty control panel, magnetron, or experiencing an issue with the power supply. Please confirm that your microwave is plug into its own outlet and that you are not using a GFI outlet. Hope this helps! - Z
Why doesn't Frigidaire FGMV174KBB microwave turntable turn?
Good Morning Friend,
I understand that the turntable is not spinning on your Frigidaire microwave, model# FGMV174KBB. There is a possibility that your microwave is in a "Turntable off" mode. To turn the turntable back on, press the "turntable on/off" button.I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
My ge micro will not stop turning
HELLO.
If by not turning mean turntable fault,the solution is given below in detail.
1 Press "Stop" to halt microwave operation.
2 Press the "Turntable" button once to turn off rotation.
3 Push the door-release button to open the microwave oven if you do not have a "Turntable" button on your control keypad.
4 Lift and remove the glass platter from the oven, then pick up the plastic track with three wheels below the platter. Set aside these parts.
5 Insert the elevated microwave cooking tray into the oven. The tray has three to four short legs that hold it above the bottom of the microwave, keeping it from interfering with the rotating bolt in the bottom center of the oven the drives the turntable. You can now place food on the elevated tray and cook normally without disrupting the drive bolt.
Thanks.
Microwave not working (generating heat)
Please check the door switch for proper operation.
2helpful
Turntable isn't working on our microwave model PLMV168. My wife defrosted a large item that was to big to rotate and forgot to turn the turntable off. After that it quit working. Is there a belt that might...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
1helpful
Microwave turntable doesn't turn. Everything else
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
I have a Frigidaire OTR microwave that will not heat. When I press start, the light inside goes on and the turntable rotates, but no heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgfgf
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Top Frigidaire Microwave Ovens Experts
Marvin
Marvin
Jaime Hernandez
Steve
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
