SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
SOURCE: error sc542
"clear modes", 1, 0 , 7, then (hold) "clear/stop" for a few seconds until "sp mode" comes up. turn main power off/on (red switch).
If code comes back there is trouble with the fuser that needs to be repaired to clear code permanently.
SOURCE: SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
[email protected]
SOURCE: Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Testimonial: "Very quick and helpful reponse. Thanks!"
SOURCE: Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
