Splendide 2100 Vented Washer-Dryer Logo
Posted on Mar 13, 2010
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 23, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1930
Points
When I use the Splendide 2100, some water comes in the front of the machine (above the the front cap on the bottom of the machine)
  • Pam Batson
    Pam Batson Jul 06, 2014
    How can i get the water out to open the door?
Anonymous
Level 1:
New Friend:
  • Posted on May 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1930
Points
Westland sales splendide parts ordering and tech support 800 356-0766
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
1helpful
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
I have a Maytag stackable washer dryer Model #MDE2400AYW A repairman has diagnosed a problem with a rim that goes around the front of the dryer barrel which rotates the dryer. The bearings have worn...
If you need the whole housing we have it available for about $45. But usually you just need the bushings $35 part # AP4045830 . If you enter your model # at www.appliancehelponline.com diagrams will come up on the left hand side you will see the housing and the bushings that support the front of the drum. There are also videos of repairing similar bearing types. All parts come with installation instructionsand are ready to ship. It is an easy inexpensive fix.
We have a Splendide WD2100 washer/dryer combination. The main door handle is broken and I need a replacement handle
I had the same problem and ordered one from Westland Sales. Phone No: 503-655-2563 Ext. 5 for parts. I believe I spoke to a gentleman named Terry. I just received mine today, cost was $52.00 including shipping.
2helpful
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Non-operational in RV when Onan generator and Xantrex inverter are on
Are you still under warranty with your RV? If so, take your RV back to them and try to get this problem fixed through them. You know more about electronics than I do (LOL) however, I do believe the RV sales/repair should be taking care of this issue for you.
I on the other hand own the Majestic brand washer and dryer and I am very dissapointed with them. The washer is broken already and is only 15 months old. Ugh!
Good luck, I hope your issue is a simple fix.
Top Splendide Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ADMIN Andrew
ADMIN Andrew
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
