Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF541 problem
Reduced creases and mini load lights are flashing and the machine wont empty. Just had the circuit board at the back replaced
Posted by stephenha307 on
Danny
    Sergeant:
  • 160 Answers
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Posted on Mar 21, 2010
  • 2 more comments
  • faulkner16 Aug 25, 2010
    I have also recently experienced the same problem - went behind machine and cleaned out all the smelly gunk in the pipe and u-bend but still experiencing machine stopping mid-cycle with the lights flashing! What's next?
  • kerenorient
    kerenorient Jul 29, 2012
    I have this problem right now - amy suggestions welcome! Thanks
  • kerenorient
    I have this problem right now - have any solutions been found? Thanks
  • Danny Jul 29, 2012
    check the sump hose underneath for blockage especially if the machine is a fair few years old..
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint washing machine wf340 will not complete a wash cycle it just stop then the lights start flashing next to the mini load button + reduced crease button and the on off button pls help
You have a bad printed circuit board (PC board). You will have to replace. I would rate this job a 4 on a hardness scale from 1 to 10. You will need your model number located on the back of the console toward the top. Go to this site and enter your model number. You can order it with a credit card 24/7 http://www.partselect.com/
Please rate this solution if helpful.
Aug 20, 2009 | Washing Machines
Hi my hotpoint wf541 will not run the start stop light and the mini load light are flashing i believe these are fault codes but have no refrences to what they are
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Apr 04, 2009 | Washing Machines
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
  • On/Off.
  • Reduced creases.
  • Mini Load.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine will not finish cycle and the reduced creases and the mini load buttons continuesly flash. Do you know how to solve this problem? My problem is same as earlier person identified sep 08. I...
Could be pressure switch jammed on empty, check pump for draining properly..
Select drain only and see if the water comes at a good rate, there are other problems that could the sequence of lights flashing that you are experiencing.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
935 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
