Question about NorStar T7316E Corded Phone
Need to change the time on my Nortel T7316E - NorStar T7316E Corded Phone
Posted by vctereso on
Anonymous
    New Friend:
  • 105 Answers
Leave the handset in the cradle and press:
Feature (star) (star) T I M E
Follow the prompts to change the time & date.
Posted on Aug 10, 2010
How do I change name showing on call display?
Do not believe that you can that comes from the phone company .
Sep 22, 2015 | Nortel Norstar T7316E Display Phone
I need the administrator password
On Nortel T7316E admin password should be 23646 - 2=A 3=D 6=M 4=I 6=N
To be sure, check out the user manual which you can get here: Nortel t7316e user manual
Nov 21, 2013 | Nortel T7316E 2-Line Corded Phone
How do we unrestrict long distant calls nortel t7316e
i got this from Nortel expert and it works:
- press feature **266344
- user ID: 738662 Press ok
- Password: 266344 Press ok
Terminal & Extensions will appear
- press Call Timer button 1 time
write your extension or the extension you need to configure
or press find till you find the extension you need
- press Ring Again button 4 times
Restrictions will appear on the screen
Restrn Filter will appear
- press Ring Again button 1 times
Filters will appear
Normal 02 will appear ( it can be any 2 numbers)
- press CHANGE which appears on the screen
Type 00
and then press the end call button
Jan 12, 2012 | Nortel T7316E 2-Line Corded Phone
I need to chjange the time on my Nortel T7316E but
The 4 top line/feature keys in the display field are used for programming. The top right arrow is the show key, the bottom right arrow is the next key, the bottom left arrow is the back key and the top left arrow is the heading key.
Mar 15, 2010 | NorStar T7316E Corded Phone
Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Feb 09, 2010 | NorStar T7316E Phone
The time is off one hour how do I fix it...Nortel
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit which will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, press back (lower left arrow)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then Chng Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Oct 28, 2009 | Nortel T7316E 2-Line Corded Phone
Time change
Below is a link to instructions on how to change the time on a Norstar system
Norstar Time change
Mar 11, 2009 | NorStar T7316E Corded Phone
How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
NorStar T7316E Corded Phone Logo
403 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
martin hogg
Ekse
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
