Masonry Tools Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to aling the the out feet table heighth to that of the blade heighth. In moving, the out feet table is higher than the blade on a Delta wood jointer 37-196.
Anonymous
Level 3:
  • Master 843 Answers
  • Posted on Mar 24, 2010
Anonymous
Master
Level 3:
Answers
843
Questions
0
Helped
394102
Points
2420
I assume you want to know how to get it adjusted just right, not how to move the outfeed table up and down. The easiest way I have found is to lay a metal ruler on edge on the outfeed table so that it extends over the blades. Slowly turn the blade forward by hand while you lower the outfeed table. Do that until the blade snags the metal ruler. Then raise the table until the blades just stop snagging the straight-edge.
Harbor Freight Warrior 10" table saw. Reset button location please?
Question edited for clarity and add maker.
Question moved from Garden to Table Saws.
Owner's Manual & Safety Instructions
Harbor Freight Tools https://manuals.harborfreight.com > manuals
DO NOT overtighten. 10. Move Blade Height Handle to 0°. Lower. Saw blade completely, then replace. Table Insert and Blade Guard.
24 pages
..My table saw one day stopped working. It had a "reset" switch I guess ... Harbor Freight Warrior 10 Table Saw Blade Issue. Nono Nom•5.1K views.
Dec 06, 2023 • Saws
Mod#113.295752 craftman table saw blade is binding trying to adjust it uprite how do i remove table top to see where its binding or what should i look for and does the top have to come off.
I am not familiar with the model so I don't know how the top comes off but usually they aren't held down by much.
Usually it only needs the plastic or aluminium insert to be removed to access the riving knife or to remove the blade.
A maladjusted riving knife is a common cause of a "catching" blade.
It is worth considering, when such saws arrive they usually need calibrating, which often means semi-dismantling the saw and rebuilding it with a higher degree of precision than the factory can muster - using a large trusted set square, an accurate blade height gauge, etc.
It is also worth considering many modern table saws also have an electric brake that is supposed to stop the blade in a couple of seconds when the power is switched off.
Oct 30, 2018 • Blade Saws
How do l tighten theblade belt on a 2010 Bolen riding lawn mower?
The blades should only be engaged when the tractor is rolling for one, deck heighth has a lot to do with the blades turning did you just change the belt? if you did did you make sure the deck height is correctly situated, meaning according to the heighth of the deck when you changed the belt, you could also not have the belt around all the pulleys or the belt may beworn out
Apr 04, 2016 • Garden
The flywheel will go backwards but, not forwards (like it is jammed), I have cleaned out and oiled around the hook area to no avail. Any other suggestions?
I believe that you have thread trimming on this machine. I have an older model. If your blades are hung up, you won't be able to turn the hand wheel forward .Unplug your foot pedal and look underneath to see if your blade is hung up and blocking the needle. I think there is a default that keeps your machine from sewing when the blade is in the way. I will need to look again but I think it is similar to an industrial Juki and has two blades: a stationary blade and a moving blade. If a glob of thread was caught in the blades or something, it can throw the setting of them off or actually break a piece of the blade off. If this appears to be the problem, a mechanic is probably your best bet.
How high above the dining room table should I hang my electric chandelier?
The height you hang your chandelier above your kitchen tabledepends on the wattage of the light bulbs and the of the chandelier. If you are using lower wattage light bulbs,you should hang the fixture about 2.5 feet above the center of your dining roomtable. If you are using higher wattagebulbs, I suggest hanging it 3 feet about the table so it is not too bright.
May 29, 2012 • Furniture
2answers
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
I just bought this table saw and when i tilt the blade to 45 deg. the blade rubs on the blade insert. also when i put it together it didnt come with a riving knife and hardware.
I ran into that kind of problem with my Craftsman 10 table saw. I (an usual) over analyzed the problem and looked at moving the entire motor assembly from left to right slightly. In the end, I found that that the blade stablizer plates I used on the left and right of the blade, moved the blade that little bit needed to make the blade tips make contact. I removed the two stablizer plates, reinstalled the blade with the normal to flat washers and gave it a try. The blade now cleared the insert when pushed all the way to 45 degrees.
You might want to look to make sure there are no extra washers/spacers on the arbor that might move the blade slightly left or right from its normal position.
1helpful
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Mower starts up fine then moves fine for about 20 feet then slows up and eventually stops moving. Also, the hydrostatic relief valve will not allow the mower to move freely
The wheels are adjusted too low causing the mower to cut the lawn very short. This will cause the blade to jam and eventually stall. Adjust the wheels so the deck is higher off the lawn and try again.
Mar 19, 2010 • Garden
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Top Delta Masonry Tools Experts
ADMIN Andrew
ADMIN Andrew
Paula Hamilton
Are you a Delta Masonry Tool Expert? Answer questions, earn points and help others
