Question about Technics SL-1200 Turntable
Need a technics 1200 turntable manual - Technics SL-1200 Turntable
Posted by tdogas on
Anonymous
    New Friend:
  • 135 Answers
User manuals and service manuals are available free of charge at :-
http://www.technicsdjuk.com/
http://www.technicsdjuk.com/Service
http://www.technicsdjuk.com/User_Manuals
Posted on Jul 05, 2010
5 Related Answers
Anonymous
  • 515 Answers
SOURCE: technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Posted on Nov 02, 2007
Anonymous
  • 515 Answers
SOURCE: Technics SL-1200MK2 Turntable i need to replace the on off switch on a mk2 technics 1200 any
The part is located HERE - but you will have to take apart your turntable from the bottom in order to replace it. It's not very hard, but if your not mechanically inclined, I would not suggest doing it, as you could cause more damage.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Posted on Apr 04, 2009
robotek
Graeme Ross
  • 1512 Answers
SOURCE: looking for manual for a turntable sl-1700
Hi
You can down load the user manual and the service manual from here
You have to register to download them, but they are for free!! Good luck, happy to answer any questions you may have.
regards robotek
Posted on Jul 08, 2009
Anonymous
  • 135 Answers
SOURCE: has anyone else had the problem with their 1200
1, The regulator circuit has failed, usually transistors Q2, Q3 and zener diode D3.
OR
2, The drive I.C (I.C101 / AN6675) has failed, this can be natural failure but also can happen if the deck is turned on and started with the platter removed.
Free Technics SL1200 / SL1210 service manual available here :-
http://stores.ebay.co.uk/methleykev
Posted on Jul 13, 2010
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
May 16, 2010 | Technics SL-1200 Turntable
Has anyone else had the problem with their 1200 technics,where the turntable doesnt spin,it judders back and forth??
OR
Dec 27, 2009 | Technics SL-1200 Turntable
Just bought a new technics sl-1200 turntable and the pitch speeds up and down causing music to sound funny....
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Dec 03, 2009 | Technics SL-1200 Turntable
MY Technics 1200 Rotates Out Of Control. What needs To Be Done To Fix?
It sounds like you need to replace the belt. If it's too loose, it will not maintain the proper speed.
Nov 04, 2009 | Technics SL-1200 Turntable
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Technics:
http://www.givemefile.net/manuals/musical_instruments/technics/sl-dz1200.html
Pioneer:
http://www.nodevice.com/user_manual/pioneer/dj_mixer/djm-600.html
Sep 22, 2009 | Technics SL-1210 Turntable
Pitch Control Problems
More than likely the pitch needs to be calibrated. Although not very hard, I would suggest getting this done by a professional, as it does require opening up your turntable.
Here are instructions - TECHNICS PITCH CALIBRATION
If you cannot perform this, then find yourself a good technician who knows what they are doing.
If this does not work, more than likely either your pitch control, the pitch gain, or one of the IC's need to be replaced - at this stage, only a qualified service tech can help you.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 28, 2009 | Technics SL-1200 Turntable
Technics multiple play spindle wearing out it seems.
Need the model number. Technics released over 100 turntables between 1970-1990 - so a model number would help us in determining what you need.
- OPTiC
Repair Videos
Turntable Repair
DJ Equipment Sales
Technics Parts
Jan 03, 2009 | Technics SL-1200 Turntable
HOW DO YOU TAKE OFF THE FACE PLATE
There is no face plate. Do you mean the actual grey cabinet? This is not easy to remove, as everything on the turntable is attached to the cabinet. So, you will have take apart the entire turntable in order to do this.
You can view a video on this sort of repair - TECHNICS REPAIR
VIDEO
- OPTiC
Technics DJ Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts
Jan 02, 2009 | Technics SL-1200 Turntable
Technics SL-1200 Turntable Logo
587 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
