Unplugged fridge overnight. Removed top freezer floor. Cleaned up all the melted water. All vents that I can see between the fridge ceiling and freezer appear clear and defrosted. Vaccummed coils at bottom. Freezer is fine. Fridge still not cold.Any thoughts?
It sounds like your circulation fan is not working. it is located in the freezer compartment in front of the evaporator or very close to it. you should hear running either all the time except in the defrost cycle. on some models the fan will shut down when you open the freezer door and restart when you close it. if the fan is OK you have a problem in your defrost circuit. probably a bad heating element or a bad defrost cutout switch or bad connections in the freezer compartment. sometimes the defrost timer can go bad but not often. I have found in my experience that the problem is usually the other two components I mentioned or bad connections.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
