Panasonic PT-LC56E Projector. Operates fine if not used before, then I turn it off and leave it for maybe upto an hour, I then try to turn it on again and the "Lamp" light starts flashing and the bulb does not turn on. Once left for a couple of hours it will turn back on again fine. Any ideas what I can do?
SOURCE: Panasonic PT-AX100
Hello
Check the process of Power supply and the outputs. powerup the projector the replace the faulty gear assy or repair the same.
viren
Rave Services India
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
SOURCE: error in panasonic lcd projector/projecteur lcd model no PT-LM1E-C
ESTOI BUSCANDO MANDO PT-LM1E-C
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
SOURCE: PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.” is displayed and select OK.
4. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
