My z4 is 4 years old 1600 hours on the lamp. Recently I began to notice that the color was not uniform on the screen. It was reddish on the left and blue on the right of the screen when watching any material.
I confirmed with a white pattern this was indeed the case and sent it to sanyo. They have replied that the "lamp assembly" requires replacement for $650.00! I have asked for clarification to what this part is and how it will correct the problem but as of yet have not had a reply. I do not believe it is simply the lamp as I do not think that it is that price.
Does anyone know what that part is and will it fix the issue?
It sounds like there might be an issue with your Aria SOHO phone system's incoming call settings or configuration. Here are some steps you can try to troubleshoot the issue:
Check the volume settings: Make sure that the volume on your Aria SOHO phone system is turned up and not set to mute. You can do this by pressing the volume up button on the phone or checking the volume settings in the phone's menu.
Check the ringer settings: Make sure that the ringer is enabled for incoming calls. You can check this by accessing the phone's menu and looking for the ringer settings option. Make sure it is set to "On" or "Enabled."
Check the incoming call settings: Check the incoming call settings on your Aria SOHO phone system to ensure that calls from outside are set to ring through to your phone. This can usually be done by accessing the phone's menu and navigating to the call settings or call routing options.
Check the cables and connections: Make sure that all cables and connections between your Aria SOHO phone system and the outside phone line are secure and properly connected.
Restart the phone system: Try restarting your Aria SOHO phone system by unplugging it from the power source and plugging it back in after a few seconds. This can sometimes help reset the system and resolve any software or configuration issues.
If none of these steps work, you may need to contact a professional technician who is familiar with the Aria SOHO phone system to help diagnose and fix the issue.
+3 Ball Handling Enter "spriteeffect" as a code to get +3 Ball Handling for your player in MyCAREER mode.
2013 All-Star uniforms Enter "mwpzoslqov" as a code to unlock the 2013 All-Star uniforms.
Christmas uniforms Enter "mnspxuwmdy" as a code to unlock the Christmas uniforms.
Heat White Hot uniform Enter "kqpxmzodqb" as a code to unlock the Heat White Hot uniform.
Secondary road uniforms Enter "ypzbnwolaw" as a code to unlock the secondary road uniforms.
Under Armour Tourch shoe Enter "underarmour" as a code to unlock the Under Armour Tourch shoe.
ABA ball Enter "payrespect" as a code to unlock the ABA ball.
At the main menu, select the "Features" option, choose the "Codes" selection, then enter one of the following codes
ABA Ball
payrespect
All-Star Uniforms
mwpzoslqov
Christmas Uniforms
mnspxuwndy
Heat White Hot Uniforms
kqpxmzodqb
Secondary uniforms
ypzbnwolaw
Unlock 3 Dribbling Moves
spriteeffect
Unlocks UA Torch Shoe
underarmour
thats the best i can do for ya
Check out this online website from where you could buy hockey uniforms in toronto. We were using uniforms from them for our team. Check out their online shopping.
I would first try a new lamp. If the reflector portion of the lamp has any defects, it could show up this way as the light would not be uniform. The next possibility is a defective light engine. The engine portion if not field repairable and would need to be replaced. Try the lamp first and let us know what happens.
