Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I've noticed a dark patch in the lower right corner of the screen. Is this a bad panel or backlight? It's mostly visible in scenes containing blues.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Sounds like a backlight is out probably due to a bad inverter board. If you can see the spot when the tv is off its probably a bad lcd panel.
Posted on Mar 13, 2010
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
Black spot on screen
all ps vita model has black
spots...panels also have defects known as
clouding (or less commonly
mura), which describes the
uneven patches of changes in
luminance. It is most visible in
dark or black areas of displayed
scenes. So you are not alone!
Mar 29, 2013 | Video Game Consoles & Games
Blue random cloudy patches have appeared on the screen of my KF-50WE610 Grand VegaLCD Projection TV. They are most noticeable in dark scenes but are now starting to be more prominant even in
You have a Bad Optical Unit Block. Go to Facebook and type in I Have A Defective Sony TV. Click Like on that Page SONY will offer you a Replacement TV!
Nov 06, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I just bought a LG 55LX6500 TV, but I found when in dark scene or no signal, the screen showing very uneven darkness, espcially the 4 corners, the most the upper left corner a lot lighter than the rest...
it may be a problem with the backlight system.the leds use a edgelit led backlight instead of placing them directly behind the lcd panel. i suggest if it is very new take it back to the store otherwise you will need to call service technician LG should be able to give you contact info for authorized servicers in your area.
Dec 23, 2010 | LG Televison & Video
Dark area on left side of screen of Dell Inspiron 1525
ok , i have had this problem on bolth my dell inspiron laptops , on a 6400 and a 1525 . the 6400 had the lower left corner all dark and the 1525 was split right down the center . i fix bolth of em in a really simple way , turn on ur pc and go into windows , press the blue Fn button and the down arrow untill ur brightness from ur backlight is completely down . keep it that way with the screen on with a screen saver for about one hour then turn brightness back up but not all the way up cuz in my case the problem hapened again , but when i keep it just one click darker , boom problem fixed . from what i can figuere out is that the inverter aint powerfull enought to power the backlight and tends to over heat , so keeping the backlight a bit lower tend the keep em ok
May 28, 2009 | Dell Inspiron 1525 Notebook
Blue patch on screen KDF-42WE655
This is problem of Optic Block (light-engine) that will be replaced and it is costly fix.
Click HERE to get price info and part image.
May 07, 2009 | Sony KDF-42WE655 Television
Faint blue vertical bars on screen
What you see on your screen are retrace lines, it can happen for various reasons. Jut lower the screen voltage by adjusting the knob specified as "screen" on the LOT, this will disappear.
Jan 27, 2008 | Sharp 32R-S50 32" TV
Cloudy patches from backlight leakage in LCD TV
You have to send it back to company to fix this problem>
Dec 04, 2007 | Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
867 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
