Question about Dell PowerEdge 1800 Server
The Poweredge does not start and does not display anything on scr
The Dell Poweredge 1800 does not start and does not display on the screen
Posted by morriskwashi on
Anonymous
    New Friend:
  • 60 Answers
The jumpers are near the CMOS battery, by the SATA ports. Sometimes clearing the NVRAM using the jumpers can work with no video issues. If it doesn't, try removing all unnecessary components - drives, cards, memory beyond a single DIMM in slot 1, etc. If that doesn't work, try reseating the processor, if there is only one. If there are two, you can try booting with a single processor (always in slot 1), swapping them to try each one. If these steps don't work, it is likely a bad board. If there are no fans spinning, lights on the front, etc., then it might be the power supply.
Unfortunately, there are no jumpers (and no BIOS setting for that matter) to disable the onboard video.
Posted on Apr 08, 2010
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
How do i enter in safe mode on my poweredge 1800 ?
If the server is running Windows, you can usually enter safe mode by repeatedly pressing F8 after you press the power switch.
You can also get into the dell utility, which lets you run memory and system tests. To access this, follow the on screen directions during boot up.
Jan 25, 2011 | Dell PowerEdge 1800 Server
Dell 1800 poweredge when I press the button does not start, I can see green light on one of the display. what cause not to boot up?
you might want to check the power supply unit first, as it is very common for them to burn out and not supply the correct power to start up the server..
the 2nd thing i would do, is do a visual inspection of the motherboard , looking for any traces of burns, if any are found, replace the server.
Jun 11, 2010 | Dell PowerEdge 1800 Server
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Power edge loght is red and blinking
You should be able to see the reasons in the front panel, remove the front cover and you will see a small display with some information passing slowly. Sometimes is just the redundant power-supply that is disconnected.
Nov 25, 2009 | Dell PowerEdge 1800 Server
Flshing Red Light on Dell Poweredge 1800 Server
I finally made contact with our IT dept who were abole to carry out a remote diagnostic test.
Problem has now been identified (problem with tape drive)
Jun 10, 2009 | Dell PowerEdge 1800 Server
I was cleanning the power edge 1800 then when i
Check to make sure cables are firmly seated...sometimes when you're inside a box, you might jiggle a cable loose.
May 02, 2009 | Dell PowerEdge 1800 Server
Available memory limited to 256
Turn off the option n the bios where it says OS Installed make sure it says os not installed
The Bios will only use 256 ram
Sep 04, 2008 | Dell PowerEdge 1800 Server
Power
Most likey the PSU is dead, or fuse on the plug socket.
Jun 26, 2008 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800
Hi satti73,
I need you to explain your problem a little more clearly.
I think you are saying that when you press the ON/OFF you get a display? What is the display that you get? How old is this machine? What other events have taken place leading up to this problem. Do you get and error messages on the monitor? DO you get any sort of sound emitting from the server when you press the ON/OFF butoon?
Nov 09, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1800 Server Logo
1,011 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
