Question about RCA P61960 61" Rear Projection Television
When plugged in, it makes a chirping sound.
I have a RCA model P61960 Chassis PTK195Y06T. When I plug it in, all it does is make a chirping sound. No picture or sound. What do I need to fix?
  • RCA Master
  • 1,527 Answers
Hello it sound like 1 of the capacitors may blown or swelled up. with the power of you need to do a visual check of the board inside check for any burn't part i'e resistor capacitors transitors diodes any more info you need get back to me
regards
shaun
Posted on Mar 13, 2010
Testimonial: "Thank you for giving me somewhere to start looking to solve the problem."
My tv will not turn on
Need alittle more info such as does the power light come on? or Blink? do you hear any sounds such as chirping or beeping?
Jun 15, 2011 | RCA P61960 61" Rear Projection Television
Tv wont turn on. it just makes a chirping noise when it is plugged in. and wen u unplug it it slows to a stop. it is a rca p61960
This is usually the flyback transformer (IHVT-integrated high voltage transformer) and the HOT( horizontal output transistor) The transistor will read shorted, with a multimeter, if it is bad. It is mounted to a heatsink straight back from the flyback. It may have a metal clip that holds it tight to the heatsink.
It is a pretty easy fix if you can solder.
While you have the board out, check for any discolored resistors and replace those as they will likely fail before long and cause more problems. Also check with a bright light and a magnifier for cracked solder joints and resolder any that you find.
Mar 01, 2010 | RCA P61960 61" Rear Projection Television
Hello i have an rca tv the pic is bowed and the letters are double i think i need a convergence kitmodel #p61960 chassis#ptk195yo6t
STK730-010 regulator it will be on board up over chassis snaller board
Call Mats Electronics fpr Part 1-800-628-1118
Dec 29, 2009 | RCA Televison & Video
I have a problem in the vertical deflection circuit on my rca tv model#p61960 chassis#ptk195y06t can you tell me where i can find a replacment board
The deflection board is part of the Main board and is not available---you do have an option---contact PTS Electronics--get a quote from them----they repair/rebuild all kinds of circuit boards---This set was made around 2002 and it is not unusual that boards are not available for it any more---someone in the chat should have known this and told you.
Let me know if you have questions or need any help.
SD TECH
Oct 03, 2009 | Televison & Video
I would like to buy a rca 61 P61960
Hi jkclay841 i live new york and have a RCA REAR PROJECTION TV 61" MODEL # P61960 CHASSIS NUMBER PTK195Y06T
IT POWERS ON BUT IT'S OUT OF ALIGNMENT ON ALL COLORS AND MISSING THE CLOTH THAT COVERS THE SPEAKERS HAVE THE REMOTE SCREEN IS IN GREAT CONDITION ALSO HAVE SOME NEW CRT COOLANT RUBER SEALS ,AND THREE NEW LENCES THAT I WAS GOIN TO REPLACE BUT CHANGED MY MIND PLUS NO TIME.
HERE IS MY NUMBER 347- 847 -3348 IM JOSE
Apr 03, 2009 | RCA P61960 61" Rear Projection Television
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
RCA P61960 61" Rear Projection Television Logo
350 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
