There is a harness that runs along the bottom of the radiator that has solider connections in it and over time they break apart. pull wires out of loom and find the corroded connection and solider or use a **** connector to fix. while you have it apart you should redo all the solider joints.
Low voltage is usually due to dirty wire connections, melted, or loose. Also if someone at somepoint in the past stabbed a wire with a sharp point like a test light, the wire will corrode and get a green chalky stuff inside the wire, which will give you low voltage.
What you need to do is re-check the voltage at the headlight connection, ground and positive, and then go to battery ground and positive at the light, to see if there is a bad ground wire. Do it with battery positive, and the ground at the light. You see where I'm going with this.
There should be a headlight relay for the left,and the right side headlights.the one for the left is bad.
