Question about Samsung HLN617W 61" Rear Projection HDTV
Timer lamp and temp flashing - Samsung HLN617W 61" Rear Projection HDTV
Posted by dans68camaro on
Steve Novak
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 149 Answers
The lamp is flashing an error code related to the temp. Count the blinks and check the manual. You may need a new bulb or the fan may not be coming on.
Posted on Mar 14, 2010
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Samsung tv lights flashing standby/timer lamp
Possible lamp or color wheel---remove the lamp and look to see it is not shattered inside.
May 30, 2012 | Televison & Video
No picture no sound lamp light and standy / temp light flashing
Two things to look at---------the lamp to see if shattered inside AND with it removed look where it faces at the color wheel--see attached photo.
Look to see if any segments are broken, missing etc. Many of the wheels fail in this way and some will have a high pitched or even fan like sound before they fail.
Some when really bad will make a grinding noise also. The set monitors the speed of the wheel and if it slows or stops the set will almost instantly turn the lamp off(if possible watch from area where lamp is to see if at turn on to see if it for a moment lights or not.
May 05, 2012 | Samsung HLR5067WX 50" Rear Projection HDTV
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Mar 14, 2011 | Televison & Video
Lamp and temp lights are flashing while in operation
clean out the projector with canned air. the dust is keeping in the heat and the lamp can't cool down. check the fans, too. check the lamp timer. if it's close to 2000 hours, replace the lamp and reset the timer.
May 11, 2009 | Office Equipment & Supplies
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Samsung HLN617W 61" Rear Projection HDTV Logo
208 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
