1991 Ford F150 Logo
Posted on Mar 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spark plug wire diagram for 91 ford f150 302
I need a spark plug wire placement diagram for 91 ford f150 302
Marvin
Level 3:
Top Expert:
  • Ford Master 85,242 Answers
  • Posted on Mar 12, 2010
Marvin
Ford Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29055435
Points
266281
toneman2121
Level 3:
  • Master 775 Answers
toneman2121
Master
Level 3:
Answers
775
Questions
0
Helped
368052
Points
2445
I have a 1985 Suzuki GS700ES. Where do wires from my 2 coil packs go to which spark plug. Thanks
The 1985 Suzuki GS700ES is a motorcycle that is equipped with two coil packs, each responsible for providing the spark to two cylinders. To determine which wire from the coil pack goes to which spark plug, you can consult the wiring diagram for your motorcycle.
If you don't have a wiring diagram, you can also determine the correct wire placement by using a spark tester. To do this, you'll need to disconnect one of the spark plug wires from a spark plug and connect it to the spark tester. Then, turn on the engine and observe which spark plug is firing. Repeat this process for each of the remaining spark plug wires until you have determined the correct placement for all of the wires.
It's important to ensure that the wires are properly connected, as incorrect placement can result in poor engine performance or damage to the ignition system.
I have a 91 ford f150 4.9 a wire on the back driver side needs to be plugged in
We do not have wiring diagrams so have no way to ID this wire for you. If you wish to buy a used wiring diagram book you can get one here. It is very easy to use and is a series of diagrams of the different parts of the electrical systems
3helpful
2answers
Spark plug wire placement and firing order for 1994 ford ranger 4.0 litre v-6
Here is the firing order diagram for that vehicle and engine, and let me know if you require any further assistance.
7helpful
3answers
Trying to find a firing order diagram for a 91 ford aerostar 4.0L V6. I have a book for it, but it is impossible to put the plug wires on the coil block in the order they describe, wires are too short! ...
For the 4.0L V6:
Firing Order:
1-4-2-5-3-6
Cylinders:
........(back)........
|...3...|.......|...6...|
|...2...|.......|...5...|
|...1...|.......|...4...|
.........(front)
Ignition Coil Connections:
..(back)
1...2...3
5...6...4
5helpful
Need to know the placement spark plug wires 2001 chevrolet malibu
do not have a diagram, but heres the firing order. 1-2-3-4-5-6, 1-3-5 is in back, # 1 is closest to alternator. from left to right, or facing engine from front 2-4-6 is in front. 5-2-3-6-4-1 is coil pack, from left to right (facing from front of engine).
Putting plug wires on a 1997 ford explorer awd that has no wires need diagram for placement
You dont need diagram. If you will notice there is seperate coils for each spark plug. you need 9/32 socket to remove each coil. Theres a small screw that holds the coil in place, Remove the srew, remove the coil, once you remove the coil take a spark plug socket and extension to remove the plug.On the end of each coil is a boot that looks like the end of a spark plug wire . You can buy a set of those boots.Do these one at a time. You can gat a book a auto parts store that could help for about twenty bucks. Hope this helps Leave comment
3helpful
Dont know correct placement of spark plug wires
try here...
http://autorepair.about.com/library/firing_orders/bl-ford-firing-03.htm
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
