Question about Ovens
Fan is working but oven not getting hot
The main oven fan comes on but ther is no heat
Posted by mariefisher1 on
Anonymous
    New Friend:
  • 40 Answers
Heating element or thermostat
Posted on Apr 07, 2010
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Main oven does not get hot the fan work and all the lights come on but none of the ements heat up
You need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Nov 22, 2010 | Neff U1661 Double circotherm super...
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
The main oven dose not heat up the fan works and
The oven element will have failed due to the fan intermittently working.
You will\ need to replace both the element, and the fan motor, to ensure a satisfactory repair.
Please rate my solution.
Thanks.
Nov 15, 2009 | Ovens
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Ovens Logo
66 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
