Posted on Mar 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rotel processor bypass for Audio Research SP10
I have a 5 channel home theater system using a Rotel RSP1098 processor, that I also want to use for 2 channel stereo using my Audio Research SP10 preamp. Is it possible to connect the SP10 directly to the Rotel pre and out to my front speakers, without degrading the tube signal from my SP10? The Rotel manual says that the signal can be input so that it only goes thru the volume pot of the Rotel but a dealer says that it actually is fed thru the Rotel circuitry and will definately not sound the same. I am trying to avoid having to disconnect and reconnect my speaker wires each time I do dedicated 2ch listening. Thanks for any info
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Mar 12, 2010
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2764830
Points
24828
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Is JVC-DVD digital cinema home theater system supports Audio return channel
Best way is to provide more information like TV model #, home theater model#
I recently got a DAV-HDX576WF system. Everything works well but I dont get any sound from the left side when in TV mode, Im using a fiberoptic cable for the sound from my TV
Failure of a digital feed can't be channel-specific. The bitstream either works or it doesn't.
It sounds more like an analog audio feed with a failing channel cable. What path does the "TV" audio follow before it gets to that fibre optic cable?
I'd draw the sound from the Cable Box and bypass the TV.
2helpful
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
I would like to buy a remote controlo for the samsung htc650w home theater system and an users manual
aha59-02291a is the model you are looking for. you might want to research getting a logitech harmony remote. a lot more functionality. make sure the harmony remote supports your receiver if thats the path you want to take.
link for the manual: http://www.samsung.com/hk_en/consumer/tv-av/home-theater/51-home-theatre-set/HT-C650W/XSH/index.idx?pagetype=prd_detail&tab=support
I just purchased an RCA RT2906 home theater system and am experiencing audio delay when switching channels on my Verizon FIOS cable box. It takes 3 or 4 seconds for the audio to kick in each time I switch...
You can try using an optical cable but you will likely run into the same issue. Each time you change the channel the digital stream is interrupted. The HT likely takes this long to start the decode process.
Need manual please for Theater Research TR-502 5.1 Surround Sound
Good day. The best I can do for you is a link where you must request the manual online. Go here http://www.audiocircuit.com/Home-Audio/Theater-Research/TR-502#manuals. Hope this helps!
3helpful
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
2answers
Rotel Amp center channel out
if you say you checked the wireing ,did you check the speaker. disconnect on of the other speakers and connect up the center to see if you get sound. still no sound speakers bad. Got sound try unpluging unit for a couple of hours then try it again. still no center . Time for the repair shop. Good Luck
 Grubhead
Grubhead
SmartAviator
SmartAviator
