Question about Biostar M6TWL (M6TWL-2.0) Motherboard
I reset the bios changing the bridge and back again because it doesn't work but now it's not working in absolute, when I turn on begins to peep! peep! one an one time again... please help!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 116 Answers
Reseat your memory SIMMS. Sound codes mean different things on different BIOS types, look up your BIOS type for the error codes.
Posted on Mar 26, 2010
Phone frozen up wont do anything not even coming on
You could try a reset.
Hold both the Home and Power buttons until the iphone begins to start.
It should take about 10 seconds.
It this does not work, your battery may be low.
Connect charger and try reset again.
Additional help from Apple support page.
If your iPhone iPad or iPod touch doesn respond or doesn turn on
Feb 21, 2015 | Apple iPhone Cell Phones
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
4 Release the GO button.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
NVRAM initialization
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
To perform NVRAM initialization
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Jul 30, 2011 | HP LaserJet 1300 Printer
Im seeing F F on the mother board display on boot up not booting wat does that mean
Check to make sure that the BIOS jumper is in the correct position (1-2), if it's even present. If that doesn't work, try clearing the BIOS (although if the jumper was set to 2-3 to begin with, then that will do absolutely nothing). If that doesn't work, try reseating the CPU, and if that doesn't work, then check for any shorts, there might be some metal shavings on some jumpers or what not, or perhaps the brass standoffs might not be on correctly. Those are all the ideas that I have.
I hope this helps!
May 06, 2011 | MSI 790FX-GD70 Motherboard & AMD Phenom II...
Password bios reset Acer extensa 5220 DipSW G39
if ur taking of how to change the bios password...den goto bios setup and reset it...if u have forget the bios password....only by removing the c-mos battery and inserting it again the bios password can b reset..
May 23, 2009 | Acer Extensa 5620 Notebook PC
Nat type changes back on ps3
you need to make sure that when you change it that you apply in your modem setup page that bridge mode is activated so that it turns it into a dumb unit allowing just to pass through the internet stream thus allowing constant nat 2 connection
Feb 05, 2009 | Zyxel P660HW-D1 Router
BIOS stops booting with two CD checks
1. Chek whether the time and date is correct
2. If No, change BIOS Battery, if Yes, No need to change the Battery
3. Install the latest Version BIOS (if the existing is the L8st, then reinstall)
4. Selct "Load Optimal Default" in BIOS and try to boot
Dec 15, 2008 | E-Machines eMachines Desktop PC
WET54G stops working
well first off u prolly got hacked, he prolly made a backdoor by now, if he changed the settings on your bridge i reccomend resetting the device to factory defaults then updating the firmware, then obtain a physical copy or digital copy of the book "wireless hacking for dummies" not saying that u r adumb or any thing but this is really good resource to teach u to tighten up your security.
May 09, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Biostar M6TWL (M6TWL-2.0) Motherboard Logo
42 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
