Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
I had to reboot my Eee PC; however, now a message comes up statting the following: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." it gives me an option to press Start Windows Normally or Last Known Good Configuration, I have pressed work but It keeps going back to the same screen. Please help
  • Anonymous Mar 13, 2010
    It did not work, the same screen is coming up. I was able to go to another screen which states:"a problem has been detected and windows has been shut down to prevent damage to your computer. This is a netbook, I do not have any CD's for this netbook. How can I fix the problem.
  • Anonymous Mar 15, 2010
    I have a netbook, it does not come with a cd player. how do i install the operating system.
Anonymous
  • 264 Answers
If you added any exta hardware means kindly remove it and boot the computer
Then you try boot by selecting the option of Boot using last known good configuration.
If the boot is successful then you can boot later booting without any problem.
If boot is not successful and this problem is happened after installing any software or driver software means boot in safe mode by pressing f8 key and uninstall it
Posted on Mar 12, 2010
    Try to repair the installation with the operating system cd.
When I turn on my asus netbook 1001 It says windows XP then tries to boot but goes to WE apologize for the inconvenience etc etc choose safe mode last known configuration or start windows normally
Try Safe mode.
Then once you're in, run your virus checker.
I like WebRoot.
Delete your browser cache, clean up the disk.
And email to yourself any files that you really want to keep so that you won't lose them in case the computer really goes down...
Mar 14, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
My other ASUS is not allowing me to go on it. When I log on it says "We apologize for the inconvenience, but Windows did not start success fully. A recent hardware or software change might hev caused...
Restart the computer and press F9. This will bring up your Asus System Recovery. Follow the prompts on screen. This will take approximately 20 mins to do but it should fix the problem. Hope this helps : ) If it doesn't or you are unable to bring up the System Recovery screen let me know.
Jan 01, 2011 | ASUS Eee 4G Notebook
It wont start up kind of
Try start, run, then type MSCONFIG go to start tab and UNcheck everything, then go to services and at the lower left of the window it says hide microsoft services and check the box then disable all then restart and see if that helps.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
Can't get the Latitude D600 to reboot
You will need to re-install windows, or use the windows recovery solution..
To use the recovery solution:
Insert your windows installation CD
reboot the computer
when prompted, push any button to boot from the CD
When asked if you want to install, or use the recovery console, select " install "
You will be promted again to install or use recovery, use " recovery "
Windows will delete hardware profile information, then continue to install as normal. Once completed, you should be able to use windows normally again, and you should not lose any data on the drive, nor any software installed or settings.
May 31, 2009 | Dell Latitude D600 Notebook
Windows laptop won't boot -
Try pressing the F8 key at start up. This should take you to safe mode, from here you will be able to shut Windows down properly and reboot without the loss on any data except for what you were working on at the time of the power loss. If it won't let you do this and stays in the same loop, it could be that the hard drive crashed and needs replacing. I don't do data recovery from a dead hard drives, so I can't give you an estimate on that, but a hard drive replacement, system reload with drivers and updates will run anywhere from $150 up to $600 depending on what you want.
Jul 01, 2008 | Gateway MX6920 Notebook
200 ARC
Try and use it in 'safe mode' by pressing F8 in advanced startup options.
Then do the system restore.
Sorry if it dosen't help but i can't really reply in fully on a forum.
Jun 29, 2008 | Computers & Internet
Acer 4710 did not reboot
Acer 4710, also has many versions.Give me the complete model # and i can help.
Jun 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
Windows XP Home Edition on HP Pavilion a367c
Are you able to successfully enter Safe Mode? Are you getting a brief blue screen before the computer restarts?
A possible solution (if you can't get into Safe Mode to further diagnose the issue) is to repair the Windows installation with a Windows XP Home CD. If you know someone with such a disk you can use that with the product key that should be on a sticker on the back of your computer. Otherwise, HP should be able to send you an XP CD since you have an authorized copy of Windows on your computer.
May 14, 2008 | Computers & Internet
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
295 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
