Question about Dremel 10 Diamond Cut-Off Wheels Saw Disc Lapidary fits
How do you cut a slab from rock with the dremel? Do you run water over it while cutting
Bob Korsu
    Guru:
  • 1,051 Answers
You can run a stream of liquid, (water or cutting oil) to reduce the heat, though it isn't always necessary. If you do use a liquid you'll need to be sure the cutting disc isn't to hot when you apply the liquid as the sudden temp change will cause the disc to fracture.
Posted on Mar 12, 2010
Testimonial: "I will try this. Thanks"
Dremel model 1695 scroll saw 45 degree cutting
Distinti gi? check in internet forum the online manuale?
Oct 04, 2018 | Dremel Saws
How to install a multipurpose cutting kit on a dremel
You will have to remove the plastic cap on the end of the tool where the tips go in. Then screw on the cutting guide.
Aug 27, 2014 | Dremel Variable - Speed Multipro Rotary...
Why does my Dremel run for 1 sec. then switches off If I knock against te side it runs 1 sec before cutting out off
sounds if your tool has a loose or broken brush this is a small carbon object inside that makes motor run, dremel does sell replacement brushes for most of what they mfg. look where ever real dremel bits and tools are sold ck package back to see if your model number is serviced by this brush pack
Aug 16, 2014 | Dremel Tools & Hardware - Others
Need to remove sticky residue from rock saw interior
I would use some sort of degrease product in the system to remove the oil residue . I believe that if you read the instructions it would say when cutting rock use only water to cool the diamond blade . Cutting oil is used only on certain metals to lubricate the saw edges and teeth as well as cooling and never in a concentration above 25% as it affects the cutting ability of the blade. For example concrete cutters use diamond saws and tap water when cutting
Mar 09, 2014 | Cars & Trucks
How to repair a water pipe leak under a concreat slab
Things to consider are cut and replace -1. Concrete saw the affected area replace and re-concrete (impact hammer is another option but a concrete saw is neater and you can control the cut better.. 2. You can bypass the pipe. 3. Dig under the slab - you obviously would need to be near an edge.
Jan 18, 2013 | Brett Plummer Android Apps
I borrowed my friend's Dremel to cut a few screws...originally she had the EZ Lock Cutting Wheel but it is too big so the smallest they make is not with the EZ Lock head so I was told to get Dremel 420...
I don't know what the numbers are, but the little abrasive cut-off wheels are held on with a mandrel type bit and a screw. Make sure you get the right size wheel and the right size mandrel, they make a couple different sizes, you can't fit the small wheels on the bigger screw. Anyway, I use my cut-off wheels all the time, usually to get stubborn screws out by cutting a slot in the head and turning it out with a flat blade screw driver. The wheels will cut anything, most people scoff when I say that, but it is true, they will cut anything.
Jul 15, 2011 | Dremel Garden
The bathtub drain pipe [below the tub] is cracked is there any easy fix without removing tub, etc  it maybe could be reached by cutting out part of the adjacent wall otherwise, the water spills onto...
You can do all your fixin underneath where you say it is leaking on the slab if there is room for you to crawl under why remove the tube, more trouble than it is worth.
Jul 18, 2010 | Home
I wished to enlarge a non-standard size hole in a foreign-make vistrous china toilet cistern, without cracking ,either by drilling or filing, what tools and advice is needed.This is to assemble either a...
The only way to cut that stuff is with diamond abrasives, on a dremel type tool, The stuff is hard as a rock and doesn't like to be messed with. A diamond core drill will cut it but not through an existing hole, no way to hold it center. Diamond grit abrasives on a drum type bit in the dremel will grind out the hole, without much stress on it. It should work. If not, the the other way would be to get silicone carbide paper or cloth wrapped around a dowel and start filing away. It will take some elbow grease, but it should cut. No other abrasive paper will touch it.,,easily,,,
May 22, 2010 | Home
Water freezes on slab & Builds Up will not fall on Wires
We had this problem. You need to clean the freezing try using a green scouring pad and the solution they recommend in the user manual. You need to scrub the tray with forward backward motions until slippery clean. All surfaces need to be clean and free of plack. it will work like new if you do this. Need to remove the cutting try first.
Feb 06, 2009 | GE Monogram ZDI15C Automatic Icemaker
Dremel 10 Diamond Cut-Off Wheels Saw Disc Lapidary fits Logo
201 people viewed this question
Top Dremel Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
Real Cool
Real Cool
Are you a Dremel Saw Expert? Answer questions, earn points and help others
